How to do force-switchover on RSP720?
rakyomin78
I found that there is no force-switchover command under redundancy configuration mode. How can I do a switchover from primary RSP720 to secondary RSP720?
I am using SSO and NSF.
C7609-2(config)#do sh redundancy
Redundant System Information :
       Available system uptime = 1 hour, 51 minutes
Switchovers system experienced = 0
              Standby failures = 0
        Last switchover reason = none
                 Hardware Mode = Duplex
    Configured Redundancy Mode = sso
     Operating Redundancy Mode = sso
              Maintenance Mode = Disabled
                Communications = Up
Current Processor Information :
               Active Location = slot 5
        Current Software state = ACTIVE
       Uptime in current state = 1 hour, 51 minutes
                 Image Version = Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRD8, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 09-Apr-12 10:54 by prod_rel_team
        Configuration register = 0x2102
Peer Processor Information :
              Standby Location = slot 6
        Current Software state = STANDBY HOT
       Uptime in current state = 1 hour, 48 minutes
                          BOOT =
                   CONFIG_FILE =
                       BOOTLDR =
rakyomin78
sorry...I have found it... it is under privilege exec mode instead...
