C1941 Crypto is not enabled .
aslam.bajwa
Level 3
Level 3
                   Hi ALL ,
i have Cisco 1941 router with following IOS image:
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.0(1)M5, RELEASE SOFTWARE (fc2)
below mentioned commands are not working :
crypto isakmp policy 5
encr aes 256
authentication pre-share
group 2
what could the issue ? do i need to change the IOS image.
regards ,
6 Replies 6
you need a security-license for that. Compare your router to the following output:
router#sh version | b Technology Package License Information
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    Permanent      securityk9
uc            None          None           None
data          None          None           None
Karsten ,
thanks for your reply .
do i need to purchase security license separately ?
If you do not currently have the security license, and if you need the crypto capability, then yes you need to purchase the security license separately.
Rick
Rick
thanks Richard ,
i have just purchased this router (Cisco 1941) , so how can i checked that whether we have security license or we have to buy .
1 - can you tell me the command to check the security license within the BOX. and if we have then how i can i enable this license .
2 - sh version out put will show the license file ?
regards ,
the command to find the license is the "show version | b Technology" above. If you see the same "security"-line you have the license. If not, your reseller will be happy to sell you the license.
Many thanks Karsten.
