Showing results forĀ
Search instead forĀ
Did you mean:Ā
adsl port (BVI1 interface on cisco router 1801) bypassed
malai.joseph
Beginner
Beginner
Have several sites and all seems to be up and running,
except one that is site  B...same configuration as others
it has intermittent disconnection on VPN,as the ASDL port of the router does not work
(interface BVI1 is down even if u try to bring it up still down).
To bypass the problem we installed a working huawei adsl modem before the router,
the solution overcome the problem
and its working BUT It seems that the modem get stuck and that's  users get disconnected.
The solution so far has been to restart the modem but now we are tired on restarting
My question is ,adsl modem installation before router could be a
problem and need to find a new cisco router with working adsl port?
                            remote sites
HQ_MPLS cisco router-------->cisco router 1801 site A
                    -------->cisco router 1801 site B
                    -------->cisco router 1801 site c
kindly help me out
joseph
antonio.guirado
Participant
Participant
Could you send the following ADSL parameters:
speed (up/down)
SNR (up/down)
attenuation (up/down)
I think the issue is in your ADSL connection that is not stable.
Regards.
Hello Antonio
thx for reply
How to get ?
speed (up/down) ?
SNR (up/down) ?
attenuation (up/down) ?
if any command or any means to extract that details pls? i would appreciate to get n will send u
thx
J
If you have the cisco router, try
show controller dsl x/x
where x/x is the ATM interface. Also if you have log enable do a "show log" a post it.
If you have the huawei adsl modem perhaps it has a little web server to manage it. Try to connect it
and look in some option about ADSL status/parameters.
Regards.
Recognize Your Peers
