Showing results forĀ
Search instead forĀ
Did you mean:Ā
SM-ES3-16-P Layer 3
SM-ES3-16-P works as a layer 3 module which means that the uplink which connects to router  ( Internally ) is a layer 3 interface . Is there a way we can use it as a layer 2 switch and connect the uplink as a trunk port ?
ahmadamr85
configure the interface as trunk and use SVIs
interface f0/0
switchport
switchport mode trunk
interface vlan <#>
! this the gateway IP address for this vlan
ahmadamr85
interface f0/0
switchport
interface vlan <#>
