Advice Needed - Cisco ASR 1002 routers & SFP's
Zubair.Sayed_2
Hi all,
We purchasing 2 x Cisco ASR 1002 routers and need to find out if the following SFP's are compatible with the ASR 1002 routers ??
- GLC-T (Copper SFP)
- GLC-SX-MM (MM Fibre SFP)
I was told by a Pre-Sales person this wont work but you know they like selling us new items all the time.
Zubair
Edison Ortiz
They are not supported, for the current supported list, please refer to the documentation:
http://www.cisco.com/en/US/docs/interfaces_modules/shared_port_adapters/install_upgrade/ASR1000/ASRsov.html#wp1071759
Hi Edison Ortiz ,
We brought CISCO ASR 1002 series router , for that i need support from your side . That is How to configure SONET Interface and WAN connective ,
Thanks in advice
Thanks & Regards
Rajkumar
Thanks Eddy.
It would be nice if you actually referenced the exact document. Giving a reference page with over 30 documents that are all over 30 pages long is not much help. I found that page myself and did not find a single document of any help with supported GBIC's for a ASR 1002-X.
