Join Customer Connection to register!
377
unpnp17
Beginner
4500 Teaming Issue
Hi Everyone,
We're teaming between 2 4500 switches (it works as active-passive) that we deploy as backbone switches. we are teaming 2 ports from 4500 to edge switches are active while some VOIPs are done but some are not. But when we command shutdown one of the teaming ports, VOIP phones are all working. how could we tshoot?
               thanks.
4 REPLIES 4
paul driver
VIP Mentor
Hello
if you aggregating on the edge ports then the device attached to them should also be able to support that aggregation?
kind regards
Paul
Please rate and mark posts accordingly if you have found any of the information provided useful.
It will hopefully assist others with similar issues in the future
Leo Laohoo
VIP Community Legend
Is the two 4500 in a VSS or not?
Yes they are working VSS.
if you still having issues you can share the configs from the 4500 and the VOIP aggregation device
