after some time SSH won't work
evgenie.daniel1
hello
i have cisco 860 router. after some days or a week i cannot use SSH anymore unless i make reboot. why is that?
9 Replies 9
Leo Laohoo
With that kind of behaviour, it sounds like an IOS bug.
Have you tried to upgrade the IOS of the router?
nope never
how to upgrade ?
Copy the IOS into the router, change the boot variable string and then reboot.
on a side note, what does your SSH configuration look like ? Are you using version 2 ? Sample config would be something like this:
ip ssh version 2
ip ssh time-out 60
ip ssh authentication-retries 3
crypto key generate rsa (1024 or higher recommended)
Have you tried removing the following lines:
no ip ssh port 2222 rotary 1
no ip ssh source-interface GigabitEthernet0
line vty 0 4
no rotary 1
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
what does it means "rotary 1"  ?
rasmus.elmholt
Level 7
Level 7
Try a show line to see if you have some old SSH connections hanging on.
I see this a lot when i configure exce-timout 0 on my line vty 0 15.
If my SSH connections is cut it will still be active on the router and when the max of 16 is reached you cannot ssh/telnet to the device anymore.
i don't have line 0 15 configured
i have only line 0 4  and it is configured with exec timeout   30
Is it because your device only support 0 4 lines?
3 of the 5 lines are currently used(the * in front of the vty line) you can manually clear the lines with clear line vty 0.
Could you do a show run all | sec line vty?
It looks like something is logging in to your device and the sessions hangs. If you want to know the ip address configure anaccess-list using access-class one the line with the log keyword.
