R1 didn't get ip from the R2 DHCP
Ibrahim Jamil
Level 6
Level 6
Hello Guys
R1(g0/0)  ---- SW1-----R2 ,
R1 G0/0 Configured with ip address DHCP
R2 is DHCP Server , SW1 does snooping on VLAN 10
R2
IP dhcp pool POOL
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
SW1
ip dhcp snooping
ip dhcp snooping vlan 10
int g1/0/1
desc connected to R2 DHCP
ip dhcp snooping trust
ip dhcp limit rate 200
R1 didn't get ip from the R2 DHCP , what is missing ,
thanks all
Ibrahim
Hello
Do you get ip address if snooping is disabled?
if so trying disabling option 82 ( if enabled) when snooping is active
review this
res
Paul
Kind Regards
Paul
6 Replies 6
Ian Walker
Is SW1 a layer 3 switch?
You'll need ip helper address adding to L3 switch
Hello Ian
it L2 Switch sir
Ibrahim
Hello
review this
res
Paul
Kind Regards
Paul
Hello Paul
so the below commands for L2 SW1
ip dhcp relay information trust all (Global)
int X/X
Desc to R2 DHCP Server
ip dhcp relay information trusted (interface)
pls advise
Ibrahim
Hello
you didn't mention it your rtr1  was  able to obtain a lease when snooping was disabled?
Kind Regards
Paul
Yep , when snooping is OFF , R1 get IP from R2
thanks
