Aggregate L3 links with different speed
J_Vansen_S
Level 3
Level 3
hi all,
I need a quick verification to proof whether this works or not.
This is a campus network.
Existing we have 5 ospf nodes interconnecting each other via layer 3 p2p 1G links.
We are installing new 10G fibers across all this 5 nodes on top of the 1G links.
So per node i will have 10G and 1G fiber going into my OSPF device.
Is it possible to aggregate both of this links 10G+1G as one?
Based on my understanding, it is not possible? in terms of aggregating links; both links has to be of the same speed.
Without the possibility of aggregating the 2 links, i would need to
  • create new p2p L3 link for the 10G
  • configure the 10G at a lower ospf cost for it to take primary path.
  • 1G link will be a redundant backup
Please correct if me i am wrong.
appreciate any advise
nurbol555
if you connect too of this links 10G+1G with each other, you can configure speed on first side like 1G, and your connect will work on speed 1G. Aggregation with different speed as i know not possible.
About your decision, it's write!
Leo Laohoo
Rule #1 with EtherChannel:  All links must have the same speed.
