aim atm 2600
ciscoenter
Hi all,
i have to setup a 2610XM router to terminate a 8Mb ATM circuit ( 4x E1 AIM ).
I bought:
2610XM
AIM-ATM
2 X VWIC-2MFT-E1
c2600-entservicesk9-mz.124-5a.bin
Now when i try to set the aim to network-clock-partecipet, the router gives me error of unrecognized command.
I check out some configuration and all of them use that command.
can u help me?
sorry for my english
thanks milko
spremkumar
Level 9
Level 9
hi
As per the datasheet the command network-clock-participate has been introduced in IOS code 12.2(2)XB, so do make sure that you are running either the same or a recent code to have the support for the same.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5012/products_feature_guide09186a00800a18a4.html
regds
i'm using a 12.4 ios
same problem with 12.3 ios
