AIM-ATM card install
alison.hou
   After installing the card, I configured :
controller T1 10/3/0
mode atm aim 1
framing esf
clock source internal
linecode b8z
But show controllers indicated it was down as follow.  did that mean the card is faulty? or maybe a circuit problem? Anything I was missing?
CAHSIBCDE#show controllers t1
T1 0/3/0 is down.
  Applique type is Channelized T1
  Cablelength is long gain36 0db
  Receiver has remote alarm.
  alarm-trigger is not set
  Soaking time: 3, Clearance time: 10
  AIS State:Clear  LOS State:Clear  LOF State:Clear
  Version info Firmware: 20050620, FPGA: 16, spm_count = 0
  Framing is ESF, Line Code is B8ZS, Clock Source is Internal.
  CRC Threshold is 320. Reported from firmware  is 320.
  Data in current interval (850 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 850 Unavail Secs
  Total Data (last 24 hours)
     481 Line Code Violations, 1555 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 86400 Unavail Secs CAHSIBCDE#show controllers t1
thanks,
alison
vmiller
Level 7
Level 7
first thing, why is clock source internal? change it to line.
thank you. I changed it line. The controllers are still down.
paolo bevilacqua
T1 0/3/0 is down.
Possible faulty circuit, or remote down.
nspasov
Also, can you post your config that includes the "clocking" commands. More specifically, I am looking to see if your aim module is set to participate in the clocking process. The command would be like this:
network-clock-participate aim 1
