Allow only ssh version 2 with aes256-cbc hmac-sha1 to IOS router
cisco24x7
Level 6
Level 6
I have a requirement on my IOS router running IOS latest version of 12.4T.
I want to configure the router so that it only accepts ssh version 2 connection with aes256-cbc hmac-sha1. Every other ssh connections such as aes192-cbc hmac-sha1 or hmac-md5 will fail.
I can get this to work on a Unix/Linux box in less than 10 seconds. However, I am struggling to get this to work in IOS routers.
Anyone know how to do this? Thanks.
17 Replies 17
Edison Ortiz
You only have 2 options for SSH server support on IOS, per the documentation:
SSH server and SSH client are supported on DES (56-bit) and 3DES (168-bit) data encryption software images only. In DES software images, DES is the only encryption algorithm available. In 3DES software images, both DES and 3DES encryption algorithms are available.
http://www.cisco.com/en/US/docs/ios/sec_user_services/configuration/guide/sec_cfg_secure_shell_ps6350_TSD_Products_Configuration_Guide_Chapter.html
I don't think you're correct. This is what I am getting when ssh into a IOS 12.4T:
debug1: SSH2_MSG_KEXINIT received
debug1: kex: server->client aes256-cbc hmac-sha1 none
debug1: kex: client->server aes256-cbc hmac-sha1 none
debug1: SSH2_MSG_KEX_DH_GEX_REQUEST sent
clearly the router is taking AES256-cbc with SHA-1.
But that's not what I am asking. I know that 3DES, AES-128, AES-192 and AES-256 are availalble on Cisco IOS. The question I am asking is how to make the IOS accept ONLY aes-256 with SHA-1.
Here is the rest of the output:
[Expert@NEO-labgw]# ssh -v -c aes256-cbc -m hmac-sha1 -l cciesec 192.168.15.201
OpenSSH_3.6.1p2, SSH protocols 1.5/2.0, OpenSSL 0x0090701f
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: Applying options for *
debug1: Rhosts Authentication disabled, originating port will not be trusted.
debug1: Connecting to 192.168.15.201 [192.168.15.201] port 22.
debug1: Connection established.
debug1: identity file /root/.ssh/identity type -1
debug1: identity file /root/.ssh/id_rsa type 1
debug1: identity file /root/.ssh/id_dsa type -1
debug1: Remote protocol version 1.99, remote software version Cisco-1.25
debug1: no match: Cisco-1.25
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_3.6.1p2
debug1: SSH2_MSG_KEXINIT sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
debug1: SSH2_MSG_KEX_DH_GEX_INIT sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_REPLY
debug1: Host '192.168.15.201' is known and matches the RSA host key.
debug1: Found key in /root/.ssh/known_hosts:9
debug1: ssh_rsa_verify: signature correct
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug1: SSH2_MSG_SERVICE_REQUEST sent
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: keyboard-interactive,password
debug1: Next authentication method: keyboard-interactive
Password:
debug1: Authentication succeeded (keyboard-interactive).
debug1: channel 0: new [client-session]
debug1: Entering interactive session.
debug1: channel 0: request pty-req
debug1: channel 0: request shell
debug1: channel 0: open confirm rwindow 1024 rmax 4096
R2851-3#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(24)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 25-Feb-09 17:55 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T5, RELEASE SOFTWARE (fc1)
R2851-3 uptime is 1 week, 1 day, 23 hours, 24 minutes
System returned to ROM by reload at 15:28:00 gmt Thu Jul 9 2009
System restarted at 15:30:07 gmt Thu Jul 9 2009
System image file is "flash:c2800nm-advipservicesk9-mz.124-24.T.bin"
R2851-3#
You are right, I wasn't correct since I posted a link that reflects the SSHv1 behavior.
This link
http://www.cisco.com/en/US/docs/ios/sec_user_services/configuration/guide/sec_secure_shell_v2_ps6350_TSD_Products_Configuration_Guide_Chapter.html
reflects the SSHv2 behavior and you can't really enforce one type of encryption from the IOS SSH server.
My only suggestion is opening a TAC case and file for an enhancement request.
Danilo Dy
To use only SSH v2, you have to fix the version with "ip ssh version" configuration command. Without doing it, you can connect to both SSH v1 and v2. SSH v1 use 3DES while SSH v2 use AES.
Check this link http://www.cisco.com/en/US/tech/tk583/tk617/technologies_tech_note09186a00800949e2.shtml#sshvvs
Again, that is not what I asked. My question is "how can I make the IOS router accept only AES256-cbc with hmac-sha-1". Anything else below aes256-cbc even with hmac-md5 will be rejected.
By the way, what you said about ssh v2 use AES is not completely accurate. ssh version 2 also uses 3DES as well. See below:
[Expert@NEO-labgw]# ssh -v -2 -c 3des -m hmac-sha1 -l cciesec 192.168.15.201
debug1: Remote protocol version 2.0, remote software version Cisco-1.25
debug1: kex: server->client 3des-cbc hmac-sha1 none
debug1: kex: client->server 3des-cbc hmac-sha1 none
Password:
R2851-3#sh run | i ip ssh
ip ssh version 2
R2851-3#
[Expert@NEO-labgw]# ssh -v -2 -c 3des -m hmac-sha1 -l root Linux_ultra_Secure
debug1: Connecting to 192.168.15.228[192.168.15.228] port 22.
debug1: Remote protocol version 2.0, remote software version OpenSSH_4.3
debug1: match: OpenSSH_4.3 pat OpenSSH*
no matching cipher found: client 3des-cbc server aes256-cbc
debug1: Calling cleanup 0x8062370(0x0)
[Expert@NEO-labgw]#
I am interested in a definitive answer to this question.
Googling and searching around Cisco.com, it seems that the answer may be: No, SSH in IOS is simply not that configurable. One only gets to choose SSH version and IOS decides what cipher to use.
Is that correct?
I was going to edit the previous post, adding "with hint from the client". But the editor does't seem to let me.
Has anyone found a resolution to this issue?  I have been searching everywhere but haven't had any luck.  This post is the only place that even mentions trying to accomplish this.  I need to complete to meet a security audit requirement.  I am going to open a case with TAC but I wanted to see if anyone had anything pop up since 2008.  Thanks in advance.
Steve
bxp
Sorry meant to reply to original post:
Steve
Steve
The part about restricting it to only SSH version 2 is easy and is explained in the post from Danilo. I am still not aware of any way to restrict the encryption protocol in IOS. If you do find something from TAC please do post back here with what you find.
Rick
Rick
This was TACs response to my question:
With  regards to your question, this functionality is not yet available on cisco IOS.
I hope this helps . Please let me know if you still require additional information/assistance or if you will want me to close the ticket.
Looks like its not an option at the moment.  I'm not sure what to bring back to the security people that mentioned we should do this.
Steve
To state the obvious, I would take back to the security people that you have asked Cisco how to do what they are requesting and Cisco has responded that in current code it is not supported. I would perhaps then ask them if they know how to do something that Cisco does not yet know.
Rick
Rick
They do know the answer:  Use Juniper .  It has that capability
It has been almost two years since the last post. I'm running Cisco IOS 15.2 now. But I have the same problem as Steven here.
I used the command "ip ssh version 2" along with the other ip ssh settings.
When trying to do a "copy scp: flash:test" it appears that the Cisco Client tries to use "3des-cbc" instead of "aes-xxxx".
I have also looked to see if I can force it to use "aes-xxxx". No Luck.
Does anyone have any suggestions, other than switching to Juniper which is NOT an option.
