10-15-2008 08:26 AM - edited 03-03-2019 11:56 PM
Hi!
I need some help how to allow smtp traffic to a exchangeserver on lanside.
I tried:
access-list out-to-in permit tcp any host 192.168.0.3 eq smtp
access-group out-to-in in interface outside
static (inside,outside) 192.168.0.3 xxx.xxx.xxx.244 netmask 255.255.255.255 0 0
Do i need to work with more outside ipadresses? Maybe it could be a bad overlap?
Kr
M
10-15-2008 08:36 AM
Is xxx.xxx.xxx.244 the address that is routable on the Internet ? If so change your config to the following
remove this static statement
Add this one
static (inside,outside) xxx.xxx.xxx.244 192.168.0.3 netmask 255.255.255.255
change access-list from
access-list out-to-in permit tcp any host xxx.xxx.xxx.244 eq smtp
Jon
10-16-2008 07:14 AM
when i add your static my internet is no longer availble. Neither is it working to access smtp from outside interface. Can i use the same adress for outside interface as i use for my static routes or do i need to create i Global outside ip-pool?
Confused!
10-16-2008 07:23 AM
Change the static statement from
static (inside,ourtside) xxx.xxx.xxx.244 192.168.0.3 netmask 255.255.255.255
to
static (inside,outside) tcp interface 25 192.168.0.3 25 netmask 255.255.255.255
I'm assuming your mail server internal address is 192.168.0.3
Jon
10-17-2008 08:35 AM
Thanks for your reply! I added some more static statement and access-list and now i'm getting performance issues from inside firewall (not sure from outside). When trying to send or recieve files it's really slow. We have 10/mbit up/down via fiber. Works good with other firewall (dlink).Is there a more effective way to open up for ports www, ssl ,rdp, smtp to internal exchange server 192.168.0.3? All these static just doesnt feel right...
PIX Version 6.3(5)
interface ethernet0 10baset
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password v0o/1tpLdUo.e/eb encrypted
passwd v0o/1tpLdUo.e/eb encrypted
hostname pixfirewall
domain-name ciscopix.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list out-to-in permit icmp any any time-exceeded
access-list out-to-in permit tcp any host xxx.xxx.134.244 eq smtp
access-list out-to-in permit tcp any host xxx.xxx.134.244 eq https
access-list out-to-in permit tcp any host xxx.xxx.134.244 eq www
access-list out-to-in permit tcp any host xxx.xxx.134.244 eq 3389
access-list VPN permit ip 192.168.0.0 255.255.255.0 192.168.10.0 255.255.255.0
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside xxx.xxx.134.244 255.255.255.0
ip address inside 192.168.0.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool VPNDHCP 192.168.10.2-192.168.10.10
pdm location 192.168.0.0 255.255.255.0 inside
pdm location 192.168.0.3 255.255.255.255 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list VPN
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp interface smtp 192.168.0.3 smtp netmask 255.255.255.255 0 0
static (inside,outside) tcp interface https 192.168.0.3 https netmask 255.255.255.255 0 0
static (inside,outside) tcp interface www 192.168.0.3 www netmask 255.255.255.255 0 0
static (inside,outside) tcp interface 3389 192.168.0.3 3389 netmask 255.255.255.255 0 0
route outside 0.0.0.0 0.0.0.0 xxx.xxx.134.1 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.0.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set matiasvpn esp-des esp-md5-hmac
crypto dynamic-map dynmapmatias 99 set transform-set matiasvpn
crypto map matiasmap 99 ipsec-isakmp dynamic dynmapmatias
crypto map matiasmap interface outside
isakmp enable outside
isakmp identity address
isakmp policy 88 authentication pre-share
isakmp policy 88 encryption des
isakmp policy 88 hash md5
isakmp policy 88 group 2
isakmp policy 88 lifetime 86400
vpngroup -matIasvpn. address-pool VPNDHCP
vpngroup -matIasvpn. dns-server 192.168.0.3
vpngroup -matIasvpn. wins-server 192.168.0.3
vpngroup -matIasvpn. default-domain netbin.local
vpngroup -matIasvpn. idle-time 1800
vpngroup -matIasvpn. password ********
telnet 192.168.0.0 255.255.255.0 inside
telnet timeout 5
ssh 192.168.0.0 255.255.255.0 inside
ssh timeout 5
10-27-2008 06:50 AM
Hi! Please look at my update!
Thanks!
10-15-2008 08:47 AM
reverse the ip addresses in your static statement.
should be: static (inside,outside) xxx.xxx.xxx.244 192.168.0.3 netmask 255.255.255.255
The first ip is the global address the second is the real address.
10-20-2008 12:27 AM
names
pager lines 24
mtu outside 1500
mtu inside 1500
pdm history enable
arp timeout 14400
http server enable
floodguard enable
telnet timeout 5
ssh timeout 5
