Alternate Internet/NAT
eduardopozo56
Hi guys, this is my first Post/Question on cisco forums, i'm a CCNA4 student and i'm having a little problem with a nat configuration:
I have to sites wich are connected by PPP, each one of them has their ISP provider and each router do the Intervlan/DHCP/Nat translation, i just need to finish the exercise with the following:
PPP link must be always down, if SITE A internet goes down, it has to use the PPP link to go to internet thu SITE B router (so SITE B router would make the NAT translation), all of this have to be done with Static Routes - Metrics.
I have tried setting up a static route to SITE B with higher metric but it is not working, SITE A router can ping the SITE B interface but hosts cant.
Any help is appreciated, ty.
Configuration is BASIC, TRUNK interface, Intervlan Routing, Nat done from Subinterfaces to Ethernet Interface connected to ISP,
Serial Interface Encapsulation PPP
Nothing fancy, ty
cadet alain
Post config of 2 routers and put ip addresses on your diagram to make things clearer.
Regards.
Alain.
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname ROUTER
ip dhcp excluded-address 192.168.0.1 192.168.0.10
ip dhcp excluded-address 192.168.0.193 192.168.0.200
ip dhcp excluded-address 192.168.0.129 192.168.0.135
ip dhcp pool DATOS10
network 192.168.0.0 255.255.255.128
default-router 192.168.0.1
ip dhcp pool DATOS20
network 192.168.0.128 255.255.255.192
default-router 192.168.0.129
ip dhcp pool DATOS30
network 192.168.0.192 255.255.255.224
default-router 192.168.0.193
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 192.168.0.1 255.255.255.128
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 192.168.0.129 255.255.255.192
interface FastEthernet0/0.30
encapsulation dot1Q 30
ip address 192.168.0.193 255.255.255.224
interface FastEthernet0/0.40
encapsulation dot1Q 40
ip address dhcp
interface FastEthernet0/0.100
encapsulation dot1Q 100
ip address 192.168.100.1 255.255.255.0
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/2/0
no ip address
encapsulation ppp
interface Vlan1
no ip address
shutdown
Router number 2 is same configuration with same ip scheme on subnet 192.168.10.X
