An E1 that doesn't consistently ping it's own interface
ngods
I have an E1 line that, when connected to a 2800, works ok (60 slipped seconds per interval.) But when connected to a 2600 series router:
E1 0/0 is up.
Applique type is Channelized E1 - balanced
Far End Block Errors Detected
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20051006, FPGA: 20, spm_count = 0
Framing is CRC4, Line Code is HDB3, Clock Source is Internal.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (371 seconds elapsed):
6961 Line Code Violations, 30565 Path Code Violations
9 Slip Secs, 0 Fr Loss Secs, 367 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 371 Unavail Secs
Total Data (last 65 15 minute intervals):
224327 Line Code Violations, 1136313 Path Code Violations,
2992 Slip Secs, 0 Fr Loss Secs, 22493 Line Err Secs, 0 Degraded Mins,
3955 Errored Secs, 1372 Bursty Err Secs, 2638 Severely Err Secs, 20077 Unavailable.
It's running a compatible OS:
ROM: C2600 Software (C2600-IK9O3S3-M), Version 12.3(20), RELEASE SOFTWARE (fc2)
The Show Diag seems slightly off, but, should be a WIC-1-MFT-E1:
WIC Slot 0:HDB3, Clock Source
E1 (1 port) WAN daughter card-CONFIG_I: Configured from console by
Hardware revision 1.0 Board revision D0
Serial number 31595174 Part number 800-04475-03
FRU Part Number WIC/VIC-E1=
nhr-am-rt
=0/0:0
Interface
IOS (tm) C2600 Software (C2600-IK9O3S3-M), Version 12.3(20), RELEASE SOFTWARE Technical Support: http://www.cisco.com/techsupportam-
[64/16]
ping 217.149.33.210 repeat 20
Sending 20, 100-byte ICMP Echos to 217.149.33.210, timeout is 2 seconds:
If I can award double points for this I will!
paolo bevilacqua
On the 2801, you need "network-clock-participate wic 0" and "network-clock-select 1 e1 0/0".
Are you sure you're receiving clock on this circuit ?
However there still too many errors and after the commands above you should have your circuit checked anyway.
It's a 2621. The 2800 works fine. Those commands don't seem to be present on the 2621, and it's just the one WIC.
On my 2611XM, I can enter network-clock-participate, are you sure you can't ?
In the general config mode, on my non-XM router 2621, there is not that command. Oh well, I'm replacing it with another 2800.
