Another Bonding, Load Balancing Question?
ccsmith705
I have seen several similar questions posted, but none of them really answered my question. Here’s my situation. I have a 7200 router at my core and a 2621 at a remote site. They are connected by a point-to-point T1. This T1 terminates into a Kentrox Add/Drop CSU/DSU. The Kentrox box handles the line configuration with the local telco. It also splits-up the T1, 12 channels for voice and 12 channels for data. The data portion is handed off to the router on a V.35 interface. I need to add a second T1 strictly for data. I will need to add another Kentrox box at both ends to terminate the new T1 and install a second T1-WIC in the 2621. The 7200 has a spare serial interface. What I will end up with is, two separate T1’s, one full T1 and one half of a T1, connecting the remote site My question is what is the best way to load balance the data across these two separate and unequal links? Can I bond them together? Any help provided is much appreciated.
Following is a sample of my routers as they are configured now.
!PARTIAL CONFIG FROM THE 7200
interface Serial5/1
ip unnumbered GigabitEthernet6/0
interface Serial5/2
no ip address
shutdown
interface GigabitEthernet6/0
!PARTIAL CONFIG FROM THE 2621
interface FastEthernet0/0
ip address 192.168.1.2 255.255.255.0
no ip redirects
no ip directed-broadcast
interface Serial0/0
ip unnumbered FastEthernet0/0
no ip mroute-cache
no fair-queue
wkumari
If you can live wuth statics, there is a fiarly cool trick that lets to do ratio based unequal cost LB.
On each device make 3 loopback addresses, and then point statics at those loopback addresses, 1 up your small link and 2 up your larger link. Now create 3 staitcs and point each at one of the 3 IPs. This will give you a 2:1 ratio.
Eg:
On 7200:
int lo 1
ip addr 10.0.72.1 255.255.255.255
int lo2
ip addr 10.0.72.2 255.255.255.255
int lo3
ip addr 10.0.72.3 255.255.255.255
On 2621:
ip route 10.0.72.1 255.255.255.255
ip route 10.0.72.2 255.255.255.255
ip route 10.0.72.3 255.255.255.255
ip route 0.0.0.0 0.0.0.0 10.0.72.1
ip route 0.0.0.0 0.0.0.0 10.0.72.2
ip route 0.0.0.0 0.0.0.0 10.0.72.3
Depending on your traffic flows you are probably doing to have to do some form of per-packet loadbalancing too.
You *may* want to just use the full T1 as a primary and the Frac as a backup. Much simpler....
You could also do EIGRP which will do unequal LB by itself, but....
wkumari
Eg:
On 7200:
int lo 1
int lo2
int lo3
On 2621:
Thank you Warren. I was looking for a temporary solution and this looks like a simple way to do what I need. I really do appreciate your help with this.
