Any Connect VPN issues with ASA 5505 Ver 8.2.5
s.thakker
Hello, I am having this issue with ASA 5505 Ver 8.2.5
I can connect to asa using vpn 3.1.xx get an ip address and shows as connected
But I can not access any resources on the remote site.
I know that I need split tunnel and is already in place.
I have no nat created between internal and vpn pool
Here is my info
Internal IP 192.168.80.0/23     VPN Pool IP 192.168.99.0/24
I have quite a few L2L vpn tunnels and they all work fine without any problems
I have attached my Running Config file and some of the screen shot from my machine when I am connected. I am completely lost. Can someone help me please?
Abhijeet Kumar
Can you post the webvpn configuration please (no running config). Please send the output of below:
- show running-config | grep webvpn
- show run nat (the nat statement for webvpn)
- show run access-list (the access-list for webvpn)
- vpn pool
Thank you
at first glance, your no_nat access list is missing a few lines (VPN pool to internal networks). Can you add the below and check if that makes a difference ?
access-list no_nat extended permit ip 192.168.99.0 255.255.255.0 192.168.80.0 255.255.254.0
access-list no_nat extended permit ip 192.168.99.0 255.255.255.0 192.168.254.0 255.255.255.0
access-list no_nat extended permit ip 192.168.254.0 255.255.255.0 192.168.99.0 255.255.255.0
