Anyone know what AIS is and what could cause Receiver is getting AIS
Anyone have any idear what could be cuasing the issue is it a Telco issue?
E1 0/0/0 is down.
Applique type is Channelized E1 - balance
Description: BT ISDN-30 IMBT Pilot
Transmitter is sending remote alarm.
Receiver is getting AIS.
alarm-trigger is not set
Version info Firmware: 20060711, FPGA: 13, spm_count = 0
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware  is 320.
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 86400 Unavail Secs
also on log:
Nov  7 06:43:39.654: %LINK-3-UPDOWN: Interface Serial0/0/0:15, changed state to down
Nov  7 17:09:43.596: %MARS_NETCLK-3-HOLDOVER: Entering Holdover for Controller E1 0/0/0
Nov  7 17:09:53.844: %MARS_NETCLK-3-HOLDOVER_TRANS: Holdover timer exceeded for Controller E1 0/0/0
Nov  7 17:09:53.844: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 1 to priority
oh, sorry, I was logged in  and it has shoed me a "secured" version of a link,
this link should be ok:
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00800a70f6.shtml
5 Replies 5
AIS usually just means that you get an Alarm from a Telco device which means the line is not operationl, see the link for troubleshootin process.
http://www.cisco.com/en/US/customer/tech/tk713/tk628/technologies_tech_note09186a00800a70f6.shtml
Konstantin, Can you post that link again as i dont have access to the URL you posted
Excellent thanks for the update.
Just FYI.  AIS stands for Alarm Info Signal and as they indicated it is the carrier sending you an alert that a facility alarm is being generated.  In some cases depending on the type of facility you may also get alerts such as CGA_Red (carrier Group Alarm_Red) which indicates the actual severity of the alarm.  Normally you should see something following an AIS alarm.  It all just depends on how your facility carrier is setup to deliver the alerts and how you are setup to receive and interpret them.
Hope this also helps.
