Apply QoS on Interface
kzhen
I want to apply the QoS service on the ATM interface, but fail.
Router#
interface ATM0/1/0
bandwidth 2048
no ip address
scrambling-payload
atm vc-per-vp 1024
no atm auto-configuration
no atm ilmi-keepalive
no atm address-registration
no atm ilmi-enable
interface ATM0/1/0.1 point-to-point
ip address 192.168.100.1 255.255.255.252
pvc 1/777
  oam-pvc manage 0
  oam retry 3 5 1
  oam ais-rdi 10 3
  encapsulation aal5nsap
Router(config)#interface ATM0/1/0
Router(config-if)#service-policy output WAN
   GTS: Not supported on this interface
Router(config-if)#interface ATM0/1/0.1 point-to-point
Router(config-subif)#service-policy output WAN
I am not sure why I am not able to apply the service policy on the ATM interface. Please help.
7 Replies 7
John Blakley
It's probably a configuration that you have in your policy map. Can you post the configuration of that?
HTH,
John
HTH, John *** Please rate all useful posts ***
ronaldobf
You will have to apply it to the VC.
Example:
Running-config of the interface:
pvc 1/777
  oam-pvc manage 0
  oam retry 3 5 1
  oam ais-rdi 10 3
To do so:
Router(config-subif)#pvc 1/777
Router(config-if-atm-vc)#service-policy output WAN
A good source:
http://www.digitalvideoheadend.com/en/US/tech/tk39/tk824/technologies_tech_note09186a00800d76b5.shtml
I hope this helps!
Hi Mikael,
Here is the show atm vc on the router
Router#show atm pvc
Interface  VCD/Name   VPI   VCI   Type   Encaps   SC    Peak Kbps   Avg/Min  Kbps   Burst Cells   Sts
0/1/0.1     1                    1    777  PVC    SNAP   UBR    1920                                                        UP
should I apply as the followings
PVC1/777
  vbr-nrt 1920 1920 1
Thank you
mlund
Level 7
Level 7
You haven't configured the vc type, and therefore the router is using it's default, wich is ubr(UnsspecifiedBitRate). You can verify this with "show atm vc".
Because the bitrate is unspecified You can't guarantee any speed.
Try to change to a vbr-rt or vbr-nrt and see if that solves the problem.
Mikael
Hi Mikael,
I applied the change on the router
pvc 1/777
vbr-nrt 1920 1920 1
It didn't show the "servie-policy output WAN" under pvc 1/777 and I didn't get any output from the " show policy-map int atm0/1/0"
Thank you
You applied it to the pvc under the subinterface. You issued a command for the physical interface only.
sh policy-map interface ATM0/1/0.1
or
sh policy-map interface ATM0/1/0.1 vc 1/777 [there are several subcommands like outbound, inbound, pvc, etc]
mlund
Level 7
Level 7
As ronaldobf pointed out, You have to do "sh policy-map interface ATM0/1/0.1"
Here is an example from our routers
interface ATM0/0/IMA0.1 point-to-point
ip address 10.x.x.x 255.255.255.252
pvc 0/35
  vbr-rt 9216 4096 1842
  service-policy output Core
router#sh policy-map interface ATM0/0/IMA0.1
ATM0/0/IMA0.1: VC 0/35 -
  Service-policy output: Core
    Class-map: Real-Time (match-any)
      5153073 packets, 454363997 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: ip dscp cs5 (40) ef (46)
/Mikael
