05-07-2012 05:15 AM - edited 03-04-2019 04:16 PM
i have 7206VXR with trunk interface toward customers, now i'm trying to configure CBWFQ on one of the sub-interfaces for specific customer,
while trying to apply parent policy which includes child policy i'm getting the following message:
Must remove traffic-shape configuration first.
here is the configured policy:
ip access-list extended ACL_TEST_SRV
permit ip any host 192.168.10.1
permit ip host 192.168.10.1 any
class-map CM_TEST_SRV
match access-group name ACL_TEST_SRV
policy-map PM_TEST_SRV
class CM_TEST_SRV
bandwdith 20 precent
policy-map PM_TEST_OUTBOUND
class class-default
shape average 9932800
service-policy PM_TEST_SRV
interface GigabitEthernet0/3.100
bandwidth 10240
service-policy output PM_TEST_OUTBOUND
Thanks and regards,
Tal
05-07-2012 06:17 AM
Tal,
Do you have generic traffic shaping enabled on the subinterface or main interface? If so, I believe you'll need to remove this before you can apply the service policy.
HTH,
John
05-07-2012 06:28 AM
Hi John,
No i don't. I had rate-limit configured but i removed it prior to applying the service-policy.
Thx,
Tal
05-09-2012 07:14 AM
class class-default
shape average 9932800 ------------------use bandwidth percent
please remove the shape average 9932800 under policy-map PM_TEST_OUTBOUND
Instead of this please use the BW percentage command it will work
02-19-2013 03:47 AM
Check and remove a shape command on the sub interface or any other sub interfaces that share that main interface.
Kentse
