11-27-2020 09:02 AM
Hi all
just a quick question, we have a sub interface configured to my isp on my isr4k
The QOS Service policy is on the physical interface, I’m assuming this will work all ok? Or do I need to put it on the sub interface?
cheers
11-27-2020 09:34 AM
yes it should be ok below guide help you : ( you need to configure on sub-interface since it tagged with dot1q)
https://www.cisco.com/c/en/us/support/docs/quality-of-service-qos/qos-policing/10104-qos-subint.html
11-27-2020 09:44 AM - edited 11-27-2020 10:29 AM
typically, QoS on subinterfaces requires a Parent - Child policy. Below an example of a very simple 100MB traffic shaper applied to a subinterface:
policy-map CHILD
class class-default
fair-queue
policy-map PARENT
class class-default
shape average 100000000
service-policy CHILD
interface GigabitEthernet0/1.10
description Subinterface to ISP
service-policy output PARENT
11-27-2020 10:42 AM
Do you have to apply it to the sub interface ? Would it not work if attached to the physical interface then ? If so how come ?
11-27-2020 11:59 AM
As mentioned subinterface are tagged with VLAN so the QOS applies based on that config ? is this make sense?
11-27-2020 03:22 PM
"Ok" depends on whether you need the policy to apply to all the traffic on the interface or if you have QoS requirements per sub interface.
