Applying route-map to 881 router interfaces
avisnyai
Good Day: Customer has three 881 routers.  FE0 connects to their WAN, FE4 connects to their LANs.  Two VLANs are configured on FE4.  Class-maps and Policy-map created to detect voice traffic:
class-map match-any VoIP-RTP-Trust
match ip dscp ef
class-map match-any VoIP-Control-Trust
match ip dscp cs5
match ip dscp af31
policy-map VoIP-Trust
class VoIP-RTP-Trust
    priority percent 70
class VoIP-Control-Trust
    bandwidth percent 5
class class-default
    fair-queue
Policy map applied to FE0 and FE4:
interface FastEthernet0
description ** WAN
switchport access vlan 20
duplex full
speed 10
service-policy output VoIP-Trust
interface FastEthernet4
description ** To LAN
no ip address
duplex auto
speed auto
interface FastEthernet4.10
description ** DATA
encapsulation dot1Q 10
ip address x.x.x.x y.y.y.y
ip helper-address x.x.x.x
interface FastEthernet4.100
description ** VOICE
encapsulation dot1Q 100
Policy map not working on FE0 (only shows traffic in class-default), but working fine on FE4 (detecting voice packets):
rtr-key#sh policy-map int
FastEthernet0
  Service-policy output: VoIP-Trust
    queue stats for all priority classes:
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 0/0
    Class-map: VoIP-RTP-Trust (match-any)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: ip dscp ef (46)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Priority: 70% (7000 kbps), burst bytes 175000, b/w exceed drops: 0
    Class-map: VoIP-Control-Trust (match-any)
      0 packets, 0 bytes
      Match: ip dscp cs5 (40)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Match: ip dscp af31 (26)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
      bandwidth 5% (500 kbps)
    Class-map: class-default (match-any)
      15744801 packets, 1038173964 bytes
      Match: any
      Queueing
      (queue depth/total drops/no-buffer drops/flowdrops) 0/0/0/0
      (pkts output/bytes output) 15744801/1038173964
      Fair-queue: per-flow queue limit 16
FastEthernet4
      (pkts output/bytes output) 3006/655308
      3006 packets, 655308 bytes
        5 minute rate 0 bps
      Priority: 70% (70000 kbps), burst bytes 1750000, b/w exceed drops: 0
      2984 packets, 1068438 bytes
        4 packets, 408 bytes
        5 minute rate 0 bps
        2980 packets, 1068030 bytes
        5 minute rate 0 bps
      Queueing
      (pkts output/bytes output) 2984/1068438
      bandwidth 5% (5000 kbps)
      779609832 packets, 304290447160 bytes
      5 minute offered rate 549000 bps, drop rate 0 bps
      Match: any
      Queueing
      (pkts output/bytes output) 779546599/304956945492
Attempted to apply policy-map to int vlan 20, but received error "Configuration failed!"
Is there a way to apply this policy to FE0 and have it work?  I know that ports FE0-FE3 are, so-to-speak, "special", and perhaps that's one of the limitations of those ports.
Thank you.
5 Replies 5
ciscoamit_497
Hi Dear,
You should need a L3 port to configure the service policy over WAN...but if there is no availability of L3 port as u said..then I think you should use the L3 interface to do that....
John Blakley
My first thought is that the switch that these phones are connected to aren't trusting the marking that the phone is doing (they do mark their own?)
A test that you could do is create another policy specifying traffic from the voice subnet. Then set the tag that you want:
ip access-list ext InVoice
     permit ip any
class-map match-all InVoice
     match access-group name InVoice
policy-map InVoice
class InVoice
set dscp ef
service-policy input InVoice
You should start seeing matches on your outbound policy map...hopefully...
HTH,
John
*** Please rate useful posts ****
HTH, John *** Please rate all useful posts ***
Jeff Van Houten
Level 5
Level 5
There's no reason to apply the policy to fe4. I'm sure your LAN can handle whatever this router is able to forward.
ciscoamit_497
You can also use the access-list so, u can match the traffic--
for example,
ip access-list extended 101 permit ip any any dscp ef
ip access-list extended 101 permit ip any any dscp af41
ip access-list extended 101 permit ip any any dscp af31
ip access-list extended 101 permit ip any any dscp cs5
And put it under lan interface as out...
ip access-group 101 out....and check the hits of the traffic..
Amit Kumar
******Please rate helpful posts********
avisnyai
I thank everyone for their input.  Here is where I am now:
I agree with Jeff that a policy-map is not needed for the LAN side of the router, so I removed it.
I created an access list as John and Amit suggested:
ip access-list extended TestVoice
permit ip any any
When I applied the ACL to outbound traffic on interface VLAN20 (which  is tied to FE0, the port used for WAN):
description ** Metro-E connection (WIN)
interface Vlan20
description ** WAN
ip access-group TestVoice out
No voice packets were being  matched:
Extended IP access list TestVoice
    10 permit ip any any dscp ef
    20 permit ip any any (131901 matches)
After that I inspected the config of the Ethernet switch at that site, and discovered that the ports were not configured to trust the DSCP markings of the traffic.  After I configured the switchports to trust the DSCP markings, I saw voice packet matches in the ACL:
    10 permit ip any any dscp ef (160156 matches)
    20 permit ip any any (262996 matches)
However, I still saw no matches for voice traffic on the policy map:
FastEthernet0
      0 packets, 0 bytes
        0 packets, 0 bytes
        5 minute rate 0 bps
      0 packets, 0 bytes
        0 packets, 0 bytes
        5 minute rate 0 bps
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
      137091 packets, 9689142 bytes
      Match: any
      Queueing
      (pkts output/bytes output) 137091/9689142
Perhaps policy-maps only work on routed interfaces?  If that's the case, I may be able to change the router config so that routed port FE4 faces to the WAN, configure one non-routed port carry the voice traffic from the switch, and configure another non-routed port to carry data traffic from the switch.
Any other ideas?
