Are there any ASR1001-X IPsec Throughput Test Report?
mhiyoshi
Level 3
Level 3
Dear all,
I have looking for the following diagram and IPsec Performance Report for instance which has verified with IMIX, short or long packet.
I think Ciscolive can be availeble to search these related document however at the moment it can not be possible.
ASR1001-X with SPA-1X10GE-L-V2(XFP-10G-MM-SR) ======OM3 Fibre Cable====== ASR1001-X Fixed 10G with SFP+ 10G-BASE-SR
*FLSA1-1X-2.5-5G license has been installed on both side.
And basically XPF and SFP+ are compatible to use 10Gbps Speed right?
Best Regards,
Masanobu Hiyoshi
Hi Balaji,
Thank you very much!
I have checked your link. So my conclution is below is that right?
ASR1001-X - Total Throughput Up to 20Gbps
                   - IPsec Throughput Up to 8Gbps
5G Performance License means 2.5Gbps x 2 = 5Gbps (Send/Receive)
ASR1001-X can accept Up to 8Gbps so it is possible rate.
Best Regards,
Masanobu Hiyoshi
