AS-Path Filtering Under Route-map
jpl861
Level 8
Level 8
Hey Guys,
Not sure what I am missing here as I cannot test it from another platform other than the one I have right now but can someone help check why AS-Path filtering under route-map isn't working?
I am trying to filter out in this lab a network routes with AS-Path 2 4 3. Here's my route-map and AS-Path filter.
R1#sh ip as-path-access-list
AS path access list 10
permit _3_3$
AS path access list 11
deny 2 4 3$
AS path access list 12
permit 2 4 3$
AS path access list 13
deny 2 4 3$
permit .*
I am trying different combinations here that's why there are multiple AS-Path ACL
Here's the route-map. (just putting some space so it will be easier to read)
route-map BGP4R2 permit 10 -  Allow the prefix if prefix-list R2IN and AS-Path. Setting local preference to identify if the route is a match
match ip address prefix-list R2IN
match as-path 10
set local-preference 10
route-map BGP4R2 permit 15 - This one I am concerned about. I am trying to block AS_Path 2 4 3 using APACL 11 but appears not to be working. I just attached a local preference to see if this sequence is somewhat permitting the route for some reason
match as-path 11
set local-preference 15
route-map BGP4R2 permit 1000 - Just a catch all and set local preference to 1000
set local-preference 1000
Here's the BGP table after applying the route-map as inbound.
R1#show ip bgp | b Network
Network Next Hop Metric LocPrf Weight Path
*> 2.2.2.2/32 10.0.12.2 0 1000 0 2 i
*> 22.22.22.22/32 10.0.12.2 0 1000 0 2 4 3 i
R1#
I can still see 22.22.22.22/32 being received with a local-pref of 1000 with AS-Path 2 4 3. That means it didn't satisfy sequence 15 and moved to sequence 1000 where it was permitted.
I tried to reverse the logic by adding another route-map sequence.
route-map BGP4R2, deny, sequence 25
Match clauses:
as-path (as-path filter): 12
Set clauses:
Policy routing matches: 0 packets, 0 bytes
The above route-map worked.
I also tried to remove the inbound route-map under BGP and replaced it with filter-list in using APACL 13 just to see if there's anything wrong with the APACL and it successfully filtered out 22.22.22.22/32.
Any idea why sequence 15 is not working? Or it's just a limitation of BGP filters under route-map?
Thanks!
JL
Here's the answer to my question.
9 Replies 9
Georg Pauwen
here is the regular expression with a filter list:
neighbor 192.168.12.2 filter-list 11 in
ip as-path access-list 11 deny ^2_3_4$
ip as-path access-list 11 permit .*
I have tried that using AS-Path ACL 13 and it worked as expected.
I am trying to use a route-map permit and AS-Path deny combo to achieve the result. I wouldn't be ble to do .* for 11 as that would permit all routes and if I decide to add other sequence after it then it may not take effect.
chrihussey
I believe you need to use access-list 12 with the permit, the 11 has a deny instance for as-path 2 4 3$, which means it won't apply.
Hope this helps
But doesn't that mean to deny 2 4 3$ path?
When I tried filter-list 13 inbound and removed the route-map, it worked as expected. So how is it different with APACL 11 then? The reverese logic APACL 12 just worked fine.
I can’t test but I think when you have a permit route map statement and a deny in your acl it just moves it on to the next route map statement.
Try using a deny route map statement and a permit in your acl.
Jon
I will test it using a simple prefix-list and see the effect.
I have already tried your suggestion with that AS-Path 12 and it worked just fine.
I was just wondering what was the logic behind the route-map permit and matching with a deny statement combo.
The deny simply means to exclude the item from that instance. So it you wish to deny something using a route map, you permit it in the ACL, but then deny it in the instance in the route map.
Hope that makes sense.
Yeah I figured that one out too just now. I used a simple prefix-list to see the effect and it was as expected.
So basically, what the router is doing is to exclude that prefix or AS-Path (in the original example) for that route-map sequence number only and take it to the next sequence of the route-map. It does not say block this route but rather take it away from this route-map sequence and continue. So yes, the correct way is to use a route-map deny sequence that says those matched permitted routes will be discarded.
R1#show route-map BGPINFILTER
route-map BGPINFILTER, permit, sequence 10
Match clauses:
ip address prefix-lists: bgp_filter
Set clauses:
local-preference 10
route-map BGPINFILTER, permit, sequence 1000
Match clauses:
Set clauses:
R1#sh ip prefix-list bgp_filter
ip prefix-list bgp_filter: 2 entries
seq 1 deny 222.222.222.222/32
seq 10 permit 0.0.0.0/0 le 32
R1#
