AS5300 using as a leased line
horvaia
I have an AS5300 router. I want to use one of the router's e1 ports for leased line.
I can't see any problem with this but it doesn't work. The line protocol
is down... What could be the problem? I'm able to see the loop at the far end so
the line seems to be ok.
Andras
Here is the config of the AS5300
controller E1 0
clock source line primary
line-termination 75-ohm
channel-group 1 timeslots 1-30
interface Serial0:1
bandwidth 1920
ip address 192.168.18.33 255.255.255.252
encapsulation ppp
Here are the outputs of the sh commands:
#sh controllers e1 0
E1 0 is up.
Applique type is Channelized E1 - unbalanced
No alarms detected.
Version info of Slot 0: HW: 1, Firmware: 4, PLD Rev: 11
Framer Version: 0x8
Manufacture Cookie Info:
EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x49,
Board Hardware Version 3.1, Item Number 800-3883-2,
Board Revision B0, Serial Number 21814499,
PLD/ISP Version 0.1, Manufacture Date 14-Aug-2000.
Framing is CRC4, Line Code is HDB3, Clock Source is Line Primary.
Data in current interval (215 seconds elapsed):
#sh interfaces serial 0:1
Serial0:1 is up, line protocol is down
Hardware is DSX1
Internet address is 192.168.18.33/30
MTU 1500 bytes, BW 1920 Kbit, DLY 20000 usec,
Encapsulation PPP, loopback not set
Keepalive set (10 sec)
LCP Listen, multilink Closed
Closed: IPCP
Last input 00:00:00, output never, output hang never
Last clearing of "show interface" counters 03:39:53
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
5 minute input rate 0 bits/sec, 6 packets/sec
5 minute output rate 1000 bits/sec, 6 packets/sec
84044 packets input, 1053800 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
973 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 973 abort
84083 packets output, 2044164 bytes, 0 underruns
0 carrier transitions
Timeslot(s) Used:1-30, Transmitter delay is 0 flags
This is the configuration of the remote end:
interface Serial0
ip address 192.168.18.34 255.255.255.252
encapsulation ppp
Serial0 is up, line protocol is down
Hardware is PowerQUICC Serial
Internet address is 192.168.18.34/30
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
Encapsulation PPP, LCP REQsent, loopback not set
Last input 00:00:01, output 00:00:01, output hang never
Last clearing of "show interface" counters 03:28:23
Available Bandwidth 1158 kilobits/sec
5 minute input rate 1000 bits/sec, 5 packets/sec
5 minute output rate 0 bits/sec, 5 packets/sec
80436 packets input, 1955214 bytes, 0 no buffer
475 input errors, 0 CRC, 456 frame, 0 overrun, 0 ignored, 19 abort
80437 packets output, 1008570 bytes, 0 underruns
0 output errors, 0 collisions, 1036 interface resets
DCD=up DSR=up DTR=up RTS=up CTS=up
5 Replies 5
Richard Burts
Andras
The major problem here is that your 5300 is treating the connection as a channelized circuit while the remote end is treating it as a straight (unchannelized) data circuit.
Rick
Rick
Rick,
Thanks for your reply. That is true. But I have plenty
other routers which works quite the same way. Those are c3640 routers and I'm using NM-2CE1U= controllers
at my end and plain wic-1t at the customers' end
for the leased line connection. So the main
difference is that the e1 ports in the AS5300 are
channelized but the NM-2CE1U= ports are unchannelized? I don't think so. Here is a part
from a sh controll e1 0/1 command from a c3640:
E1 0/1 is up.
No alarms detected.
Andras
let me answer my own question, maybe somebody else
would run into the same issue in the future.
It seems that it was an ios bug in c5300-is-mz.121-4a.bin ios. I did an upgrade to
c5300-is-mz.121-27b.bin and everything works fine.
Andras
Thanks for posting with the solution. It helps make the forum more useful when we can read about a problem and then can see what the solution to the problem is. I encourage you to continue to be active in the NetPro forum.
Rick
Rick
Rick
where can we see the remote end is treating it as a straight (unchannelized) data circuit?thx
