RRI how can I make this
Krasnoperov
I''ve problem, can you please advise how can I make this.
Here we have a picture, how to RRI works
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00809d07de.shtml
what is instead of PC on the left, we have another little ASA with some other routes, for example it connected to another roter and get some routes through EIGRP, how can I inject all routes from my little ASA to OSPF?
thx
Nagaraja Thanthry
You can use the example listed in the following link:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00804acfea.shtml#rri
If you are running EIGRP on the remote end, please run OSPF as well and then redistribute EIGRP routes into OSPF.
Hope this helps.
NT
