ASA 5505 - Access Rule issue
matumero84
I am trying to add an access rule to my list, but am receiving the following error. Can anyone shed some light on this?
access-list inside_access_in line 1 extended permit udp 0.0.0.0 0.0.0.0 range 15^000 15200 host 192.168.5.216 range 15000 15200
% Invalid input detected at '^' marker.
rmeans
Level 3
Level 3
Interesting.
i cut/paste your acl (changing the name to test) and didn't have any trouble.  My ASA is running OS 8.2.4.  I did a quick search (access-list and range) of the bug toolkit and didn't find anything.
access-list test line 1 extended permit udp 0.0.0.0 0.0.0.0 range 15000 15200 host 192.168.5.216 range 15000 15200
show access-l test
access-list test; 1 elements; name hash: 0xcb4257a3
access-list test line 1 extended permit udp any range 15000 15200 host 192.168.5.216 range 15000 15200 (hitcnt=0)
If you change the 0.0.0.0 to any do you still get the error?
Pablo
Hi Marco,
I tried this on my ASA but had no problems at all,
ASA(config)# show run access-list
access-list inside_access_in extended permit udp any range 15000 15200 host 192.168.5.216 range 15000 15200
There's gotta be a character limitation on your SSH terminal client; as rmeans indicated try with any instead of the 0.0.0.0 blocks.
__ __
Pablo
matumero84
I'm using CLI on ASDM 5.2. I'm receiving lots of strange errors. Including some of the commands from the drop down box. I tried show running-config and I get an error as well.
Result of the command: "show running-config"
show running-config
ERROR: % Invalid input detected at '^' marker.
Could there be an issue with the unit?
This command works
Result of the command: "show version"
Cisco Adaptive Security Appliance Software Version 7.2(3)
Device Manager Version 5.2(3)
