04-16-2022 06:35 AM
Hello
i define subinterface on port Gi1/8.10 VLAN10 and create a trunk on the Switch side.
but if connecting any client to Gi0/4 can't ping the FW 192.168.10.1.
thanks for any update.
ASA5506-x
interface GigabitEthernet1/1
desc ** WAN **
nameif outside
security-level 0
ip address dhcp setroute
interface GigabitEthernet1/2
no nameif
no security-level
no ip address
interface GigabitEthernet1/3
no nameif
no security-level
no ip address
interface GigabitEthernet1/4
bridge-group 1
nameif inside_2
security-level 100
interface GigabitEthernet1/5
Desc ** ESXi **
bridge-group 1
nameif inside_4
security-level 100
interface GigabitEthernet1/6
bridge-group 1
nameif inside_5
security-level 100
interface GigabitEthernet1/7
Desc ** ESXi **
bridge-group 1
nameif inside_6
security-level 100
interface GigabitEthernet1/8
Desc ** Switch **
bridge-group 1
nameif inside_7
security-level 100
interface GigabitEthernet1/8.10
description ** WIFI **
vlan 10
nameif vlan10
security-level 80
ip address 192.168.10.1 255.255.255.0
interface BVI1
nameif inside
security-level 100
Switch
int Gi0/10
description ** to ASA-5506-X **
switchport mode trunk
udld port aggressive
spanning-tree portfast
int Gi0/4
description ** Wifi **
switchport access vlan 10
switchport mode access
Port Mode Encapsulation Status Native vlan
Gi0/10 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi0/10 1, 10
04-16-2022 10:10 AM - edited 04-16-2022 10:10 AM
Below setup is a bit confuse to me. BVI usually we uses for firewall in transparent mode (Just a note).
Then, I see different security level for interface and subinterface, not sure why. Lastly, firewall does not reply ping always and this is not actually a problem but can be for security.
Make sure you are not testing something you can´t get the result you want.
If you explain better your setup and maybe share some topology would be easier to get helped.
Desc ** Switch **
bridge-group 1
nameif inside_7
security-level 100
vlan 10
nameif vlan10
security-level 80
interface BVI1
nameif inside
security-level 100
04-16-2022 11:59 AM - edited 04-16-2022 12:11 PM
At first glance it seems you have udld port aggressive configured on the switch's trunked interface facing the ASA, but udld is not configured on the ASA side. I would suggest removing the udld configuration, or matching the config on the ASA.
