Asa 5508-x dead primary. Need Secondary to copy config to RMA ASA
dmooreami
Level 3
Level 3
had the primary die, but secondary is up.
I am fuzzy on the trick to get the active/secondary to replicate the config over to the new "blank" rma ASA.
Best I recall is
  1. I need to copy all the interface commands over to the "new" blank asa.
  2. Something about failover commands and switch primary with sec.
then memory starts failing.
Isn't it better to make my current "secondary" the new Primary with a
failover lan unit primary
I realize there will be a short outage.
Before copy of config :
  • copy over primary IOS to rma asa
  • copy primary ASDM to rma.
  • copy anyconnect pgk files
  • copy xml files that deal with anyconnect
Next on the new blank asa,
  1. copy all interface commands
  2. change failover commands on rma  to "failover lan unit secondary"
  3. Then connect ONLY the failover interface cable only.
  4. the new primary should copy its config over to the rma ASA.
  5. Naturally I will have to copy over all the anyconnect.pkg, and make sure the IOS and asdm are same version as my primary
Please correct me when needed.
marce1000
 - Check these threads : https://community.cisco.com/t5/network-security/replacing-primary-asa-in-h-a-pair/td-p/3369761 and https://community.cisco.com/t5/network-security/asa-failover-pair-hw-replacement/td-p/1445549
balaji.bandi
Does the ASA have SFR Module (and Live ?)
easy method, New ASA RMA, prepare offline with the same code as Secondary.
Confgure only sync and Manangement
disable any monitor configured, so its not failover
connect to Management and sync link only so config will be replicated to mate.
Once Sync completed - connect other cables and check all the interface up and working, enable monitoring
test some failovers.
BB
