ASA 5520 Logging Help
Eddie.brown1986
Hello Folks,
I am running two ASA 5520 routers synched up with eachother. I had a massive connectivity issue this weekend that I am investigating. Now I have figured out how to get the live logging but I need to know how to get the old logs from my router.
Also I am looking to set up a log dump that could happen daily or perhaps weekly. Does anyone have any experience with this?
Eddie
ajay chauhan
Level 7
Level 7
Basically you need to setup logging server for firewall/router. If you want to store logs daily/weekly/monthly basis.
Devices logs will be genrated based on configuration level.
LevelSystemDescription
Emergency0System unusable messages
Alert1Immediate action required messages
Critical2Critical condition messages
Error3Error condition messages
Warning4Warning condition messages
Notification5Normal but significant messages
Information6Informational messages
Debugging7Debugging messages
http://www.cisco.com/web/about/security/intelligence/identify-incidents-via-syslog.html#9
