ASA Access Lists
BHconsultants88
Level 4
Level 4
Hi guys
Really hope someone can help with this, it's driving me up the wall. I have an ASA with a number of ACL's configured (examples below):
access-list Inside_nat0_outbound extended permit ip 10.154.246.0 255.255.254.0 object-group All_HQ_VPN_Protected_Networks
access-list Outside_20_cryptomap remark This rule protects traffic destined for HQ's internal private networks.
access-list Outside_20_cryptomap extended permit ip object-group BLADEInternal object-group All_HQ_VPN_Protected_Networks
access-list Inside_access_in extended permit ip object-group BLADEInternal object-group DM_INLINE_NETWORK_5
access-list Outside_access_in extended permit tcp object data.meetingmatrix.com 10.154.246.0 255.255.254.0 object-group WebServices
I need to deny Internet traffic temporarily. When I add a firewall rule on the ASDM gui, it shows on command line like this:
access-list Inside_access_in_1 extended deny ip any any
Two questions:
  1. why does the deny rule appear on interface Inside_access_in_1 (what does the _1 represent?)
  2. Can I apply this deny rule on Access List, not on the firewall?
Thank you
johnd2310
Level 11
Level 11
When creating the access-list rule, you need to choose the access-list you are adding the rule to. You probably just chose the interfaces and the firewall created a new access-list for you.Inside_access_in_1 is probably an access-list the firewall created for you.
If the access-list for your Internet traffic is  Outside_access_in, then you will need to choose this access-list in asdm and apply the deny rule to this access-list.
John
**Please rate posts you find helpful**
Ok thanks for the reply.
So would I have to always have the deny rule in the firewall. Would it be the same thing if I added it to the ACL manager?
