ASA ACL between Interfaces
s.mallonee
Have a interesting topology layout that I am trying to work with.
ASA
interface Ethernet0/1
description GCI connection
nameif GCI-Inside
security-level 100
ip address 10.116.0.1 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
nameif Akmaaq-LAN
security-level 100
ip address 192.168.70.7 255.255.255.0
eth 0/3 is attached to a switch (192.168.70.7) which is attached to a router that houses the 192.168.70.0/24 network.
eth 0/1 is its own network (10.116.0.0) that is a terminating point for vpn S2S tunnels ranging from 10.116.1.0 - 10.116.20.0.
route Akmaaq-LAN 10.51.0.0 255.255.0.0 192.168.70.1 1
The subnets on 10.51.0.0 are accessible via 192.168.70.1.  The 10.116.0.0 will need to access 10.51.0.0 and 192.168.70.0/24.
same-security-traffic permit inter-interface
The above command is in place.
I am horrible with ACL's and I beleive I need ACL's inplace to make this routing possible.
I have been looking at some of cisco's documentation and have added in ACL's from their examples and had no success.  I have also been searching through this forum and not found any commands that have made this work.
Sean
p.mcgowan
Level 3
Level 3
does the 10.51.0.0/16 network have a route to the 10.116.0.0/24 network?
10.51.0.0/16 may be accessable from 192.168.70.0/24 but if you want to access this network from 10.116.0.0/24 you must make sure that 10.51.0.0/16 has a route to 10.116.0.0/24
Please check and let me know
Please rate post if helpful
The 10.51.0.0/16 has a route to 10.116.0.0 via 192.168.70.1 and there is a route in 192.168.70.1 to 10.116.0.0 via 192.168.70.7.
When I run the packet-tracer from GCI-Inside (10.116.0.1) to Akmaaq-LAN 192.168.70.7 it comes back with a drop result due to explicit rule.
I figure its an ACL thats not inplace but everything i have tried hasn't produced an answer.
Sean
