DSL Disconnection With ATM interface
Elie Bassil
I have a scenario where multiple branches are connected to Head Office via DSL links. The branches are located in differenct exchanges, everyone once in a while ALL branches go down at the exact same time except 3 branches and those 3 branches don't have ATM interface on the router, rather they have external DSL modem, all other branches that face the disconnection (for couple of minutes) have either HWIC-1ADSL-M or HWIC-2SHDSL and the DSL line is directly plugged into the card. Here is a sample configuration of the routers facing the disruption:
interface ATM0/0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no atm ilmi-keepalive
interface ATM0/0/0.1 point-to-point
description ADSL
mtu 1500
bandwidth 1000
ip address 192.168.241.17 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
atm route-bridged ip
crypto map DSL
pvc 0/35
  encapsulation aal5snap
I tried so many solutions like adding "operating-mode auto" command under the subinterface, IOS upgrade, changed dynamic routing protocol from EIGRP to OSPF... Nothing worked, on the logs of the router it just shows "EIGRP neighbor down", at the time of the problem I can't ping any of the affected branches on their WAN ATM interface although it stays physically "up up".
Could the problem be a missing command that I need to add under the subinterface? Something maybe related to clocking or timeout or..?
Note that hte problem occurs randomly, every few days, sometimes every 10 days, and all branches with ATM interface go down at the exact same time.
E.B:.
5 Replies 5
paolo bevilacqua
How you can tell they go down at the same time?
Any, send "show dsl interface", taken on the troubled branches only.
I have a monitoring tool that monitors all the branches, it goes all red when the problem occurs except for the 3 branches where there is an external DSL modem.
command not supported, find "sh interface" output if that helps
ATM0/0/0 is up, line protocol is up
  Hardware is DSLSAR, address is c84c.75fd.1fa3 (bia c84c.75fd.1fa3)
  MTU 4470 bytes, sub MTU 4470, BW 2304 Kbit/sec, DLY 110 usec,
  Encapsulation ATM, loopback not set
  Keepalive not supported
  Encapsulation(s): AAL5
  8 maximum active VCs, 256 VCs per VP, 1 current VCCs
  VC Auto Creation Disabled.
  VC idle disconnect time: 300 seconds
  Last input 00:00:00, output never, output hang never
  Queueing strategy: Per VC Queueing
  5 minute input rate 7000 bits/sec, 5 packets/sec
  5 minute output rate 2000 bits/sec, 1 packets/sec
     1410023 packets input, 197277896 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 1509 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     103046 packets output, 19325143 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
ATM0/0/0.1 is up, line protocol is up
  Internet address is 192.168.241.12/24
  MTU 1500 bytes, BW 2000 Kbit/sec, DLY 110 usec,
  Encapsulation ATM
     103046 packets output, 18912959 bytes
     0 OAM cells input, 0 OAM cells output
  AAL5 CRC errors : 0
  AAL5 SAR Timeouts : 0
  AAL5 Oversized SDUs : 0
10x for looking into this dazzling issue
E.B:.
You should have "show dsl" commands because you have an ADSL interface. It is crucial to look at ADSL line and firmware information. Please check again. Alse send show ver, show diag.
yes you are right:
------------------ show dsl interface ------------------
ATM0/0/0
Alcatel 20190 chipset information
Line not activated: displaying cached data from last activation
                ATU-R (DS)                      ATU-C (US)
Modem Status:    Showtime (DMTDSL_STOP)
DSL Mode:        ANSI T1.413
ANSI Issue/rev:  2/1                             2/1
Vendor ID:       0x003A                          0x0054
Chip ID:         C196 (3) capability-enabled
DFE BOM:         DFE3.0 Annex M (3)
Capacity Used:   62%                             28%
Noise Margin:    12.5 dB                         28.0 dB
Output Power:    15.0 dBm                        11.5 dBm
Attenuation:     66.0 dB                         31.5 dB
FEC ES Errors:    0                               0
ES Errors:       4582                            310
SES Errors:       0                               0
LOSES Errors:     0                               0
UES Errors:       0                               0
Defect Status:   None                            None
Last Fail Code:  None
Watchdog Counter: 0xD5
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction:     0x00
Interrupts:      28939 (0 spurious)
PHY Access Err:  0
Activations:     28
LED Status:      OFF
LED On Time:     0
LED Off Time:    0
Init FW:         init_AMR-4.0.015_no_bist.bin
Operation FW:    AMR-4.0.015.bin
FW Source:       embedded
FW Version:      4.0.15
                 Interleave             Fast    Interleave              Fast
Speed (kbps):           512                0           128                 0
Cells:              6358834                0      27079623                 0
Reed-Solomon EC:      47318                0           341               343
CRC Errors:             970                0           348               327
Header Errors:          272                0           325               333
Total BER:                0E-0           0E-0
Leakage Average BER:      12288E-117             0E-0
Bitswap:               enabled            enabled
LOM Monitoring : Disabled
DMT Bits Per Bin
000: 0 0 0 0 0 0 0 0 2 3 4 4 4 4 4 4
010: 0 3 3 3 3 3 3 2 2 2 2 2 2 2 2 0
020: 0 2 2 2 2 2 2 3 3 4 2 3 4 3 3 3
030: 4 3 3 3 2 2 2 0 0 0 2 3 3 4 4 4
040: 0 4 2 0 2 2 2 3 5 5 4 3 4 4 4 4
050: 2 4 4 2 0 0 4 4 4 3 3 3 4 3 3 3
060: 4 3 3 0 0 0 0 2 2 0 0 0 0 0 0 0
070: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
080: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
090: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0A0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0B0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0C0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0D0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0E0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0F0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
DSL: Training log buffer capability is not enabled
------------------ show version ------------------
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.0(1)M1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 02-Dec-09 15:23 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M1, RELEASE SOFTWARE (fc1)
Bekaata uptime is 14 weeks, 3 hours, 13 minutes
System image file is "flash0:c2900-universalk9-mz.SPA.150-1.M1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2911/K9 (revision 1.0) with 475136K/49152K bytes of memory.
Processor board ID FHK1352F36T
3 Gigabit Ethernet interfaces
2 Low-speed serial(sync/async) interfaces
1 ATM interface
1 Virtual Private Network (VPN) Module
2 Voice FXO interfaces
2 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2911/K9
Technology Package License Information for Module:'c2900'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      securityk9    Permanent     securityk9
uc            uck9          Permanent     uck9
data          None          None          None
------------------ show diag ------------------
Slot 0:
        C2911 Mother board 3GE, integrated VPN and 4W Port adapter, 10 ports
        Port adapter is analyzed
        Port adapter insertion time 14w0d ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        :
        Hardware Revision        : 1.0
        Part Number              : 73-11833-03
        Top Assy. Part Number    : 800-30797-01
        Board Revision           : B0
        Deviation Number         : 0
        Fab Version              : 03
        Product (FRU) Number     : CISCO2911/K9
        Version Identifier       : V01
        CLEI Code                : COMGM00ARA
        Processor type           : C1
        Chassis Serial Number    :
        Chassis MAC Address      : 8843.e116.ef40
        MAC Address block size   : 80
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 33 34 39 35 31 50 56 40
          0x10: 06 18 41 01 00 82 49 2E 39 03 C0 46 03 20 00 78
          0x20: 4D 01 42 42 30 88 00 00 00 00 02 03 CB 8C 43 49
          0x30: 53 43 4F 32 39 31 31 2F 4B 39 89 56 30 31 20 D9
          0x40: 04 40 C1 CB C2 C6 8A 43 4F 4D 47 4D 30 30 41 52
          0x50: 41 09 C1 C2 8B 46 48 4B 31 33 35 32 46 33 36 54
          0x60: C3 06 88 43 E1 16 EF 40 43 00 50 C4 08 00 00 00
          0x70: 00 00 00 00 00 F3 00 03 40 01 25 FF FF FF FF FF
          0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        Internal power Supply information
        Top Assy. Part Number    : 341-0235-03
        PCB Serial Number        :
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Product (FRU) Number     : PWR-2911-AC
        CLEI Code                : TYCOCONNEC
        Board Revision           : A0
          0x00: 04 FF 40 05 E5 DF 45 01 55 00 EB 03 88 00 00 00
          0x10: 00 C1 8B 41 5A 53 31 33 34 36 30 35 36 35 03 00
          0x20: 81 00 00 00 00 04 00 89 56 30 31 20 CB 8B 50 57
          0x30: 52 2D 32 39 31 31 2D 41 43 C6 8A 54 59 43 4F 43
          0x40: 4F 4E 4E 45 43 F3 00 59 41 00 BE 42 00 05 F8 00
          0x50: 50 01 F3 17 32 02 EE 1A 9F 03 E6 1B B4 04 E3 1C
          0x60: 99 05 DC 1D 7B 06 D6 1E 3C 07 D3 1E E7 08 C9 1F
          0x70: 5A 09 C6 1F D5 0A BC 20 20 0B B9 20 74 0D 92 20
          0x80: A0 0F 8C 21 28 11 85 21 5F 13 7F 21 9D 17 71 21
          0x90: F3 1B 57 22 08 1F 40 22 18 23 37 22 27 27 10 22
          0xA0: 09 42 41 30 FF FF FF FF FF FF FF FF FF FF FF FF
        PVDM Slot 0:
        16-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
        Part Number              : 73-11576-03
        Board Revision           : B0
        Fab Version              : 03
        PCB Serial Number        :
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM3-16
          0x00: 04 FF 40 05 D8 41 01 00 82 49 2D 38 03 42 42 30
          0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 33 35 31
          0x20: 33 5A 48 35 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 8F 50 56 44 4D 33 2D 31 36 20 20 20 20 20 20 20
          0x40: 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 0:
        ADSL over POTS Annex M
        Hardware Revision        : 3.0
        Top Assy. Part Number    : 800-28201-03
        Part Number              : 73-10885-03
        Board Revision           : B0
        Fab Version              : 07
        PCB Serial Number        :
        RMA History              : 00
        Product (FRU) Number     : HWIC-1ADSL-M
        Version Identifier       : V03
        CLEI Code                : COUIAFDCAB
          0x00: 04 FF 40 05 66 41 03 00 C0 46 03 20 00 6E 29 03
          0x10: 82 49 2A 85 03 42 42 30 88 00 00 00 00 02 07 C1
          0x20: 8B 46 4F 43 31 34 32 33 32 4B 32 54 03 00 81 00
          0x30: 00 00 00 04 00 CB 92 48 57 49 43 2D 31 41 44 53
          0x40: 4C 2D 4D 20 20 20 20 20 20 89 56 30 33 20 D9 02
          0x50: 40 C1 C6 8A 43 4F 55 49 41 46 44 43 41 42 FF FF
        EM Slot 0:
        ADSL over POTS Annex M non-removable daughtercard
        Part Number              : 73-10886-03
        Board Revision           : C0
        Fab Version              : 01
        PCB Serial Number        :
        RMA History              : 00
        Fab Part Number          : 28-8925-01
        Field Diagnostics Data   : 00 00 00 00 00 00 00 00
        Connector Type           : 01
          0x00: 04 FF 40 05 67 41 03 00 82 49 2A 86 03 42 43 30
          0x10: 88 00 00 00 00 02 01 C1 8B 46 4F 43 31 34 32 32
          0x20: 34 53 51 4E 03 00 81 00 00 00 00 04 00 85 1C 22
          0x30: DD 01 C4 08 00 00 00 00 00 00 00 00 C5 08 00 00
          0x40: 00 00 00 00 00 00 05 01 89 56 30 33 20 FF FF FF
        WIC Slot 1:
        HWIC Serial 2A/S
        Top Assy. Part Number    : 800-28900-02
        Board Revision           : A0
        Fab Version              : 01
        PCB Serial Number        :
        RMA History              : 00
        Fab Part Number          : 28-8141-01
        Product (FRU) Number     : HWIC-2A/S
        Version Identifier       : V02
        CLEI Code                : COUIA1PCAA
          0x00: 04 FF 40 05 8E 41 01 00 C0 46 03 20 00 70 E4 02
          0x10: 42 41 30 88 00 00 00 00 02 01 C1 8B 46 4F 43 31
          0x20: 33 35 30 32 36 35 52 03 00 81 00 00 00 00 04 00
          0x30: 85 1C 1F CD 01 CB 89 48 57 49 43 2D 32 41 2F 53
          0x40: 89 56 30 32 20 D9 02 40 C1 C6 8A 43 4F 55 49 41
          0x50: 31 50 43 41 41 FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 2:
        3rd generation - FXS DID Voice daughter card (2 port)
        Top Assy. Part Number    : 800-30501-02
        Board Revision           : A0
        Fab Version              : 07
        PCB Serial Number        :
        RMA History              : 00
        Product (FRU) Number     : VIC3-2FXS/DID
        CLEI Code                : IP9IAB3CAB
        Longitudinal Calibration : 01 10 10 94 9E 10 10 9F
                                   8A
          0x00: 04 FF 40 06 21 41 01 00 C0 46 03 20 00 77 25 02
          0x10: 42 41 30 88 00 00 00 00 02 07 C1 8B 46 4F 43 31
          0x20: 33 34 38 32 35 54 44 03 00 81 00 00 00 00 04 00
          0x30: CB 8D 56 49 43 33 2D 32 46 58 53 2F 44 49 44 89
          0x40: 56 30 32 20 D9 02 40 C1 C6 8A 49 50 39 49 41 42
          0x50: 33 43 41 42 D3 09 01 10 10 94 9E 10 10 9F 8A FF
        WIC Slot 3:
        2nd generation - FXO Voice daughter card (2 port)
        Hardware Revision        : 5.0
        Top Assy. Part Number    : 800-21597-03
        Board Revision           : B0
        Deviation Number         : 0-0
        Fab Version              : 04
        PCB Serial Number        :
        RMA History              : 00
        Product (FRU) Number     : VIC2-2FXO
        CLEI Code                : CNUIARTAAB
          0x00: 04 FF 40 00 4D 41 05 00 C0 46 03 20 00 54 5D 03
          0x10: 42 42 30 80 00 00 00 00 02 04 C1 8B 46 4F 43 31
          0x20: 33 34 34 35 39 5A 38 03 00 81 00 00 00 00 04 00
          0x30: CB 89 56 49 43 32 2D 32 46 58 4F 89 56 30 32 20
          0x40: C6 8A 43 4E 55 49 41 52 54 41 41 42 FF FF FF FF
The ADSL line seems troubled, a lot of activations, some errors, very low speed despite attentuation and noise margine within acceptable limits.
And DSL mode should be ITU T not ANSI.
The most important thing is that you try ADSL firmware 4.0.17, that requires a support contract to be downloaded.
If you cannot easily get the support contract, try asking TAC is they can open the case on the basis that you have a new product malfuctioning. TAC may also have newer, unpublish ADSL firmware to address your problem.
Also you can try rehauling all internal wiring, ADSL filters, etc. Here a link
http://www.kitz.co.uk/adsl/lowSNR.htm
What is puzzling is that you see branches connected to different COs go down at the same time, you would have to look at logs with timestamps to verify that. It might be something flapping in ISP network between you and the nodes,
Thanks for the nice rating and good luck!
