ASA Captures
manningjt07
How do I configure a wireshark capture on the ASA?
5 Replies 5
teatrodelsogno
Wireshark?!?
Isn't enough the logging on the ASA?
Or in case, you can send the logs to an external syslog for further analyzing on it (also wireshar). But this is depending of which tools on syslog you're using.
regards
rakeshvelagala
Level 3
Level 3
What is the issue and what are you trying to check?
You can use this link to set up captures then, export them and analyze them on Wireshark:
https://supportforums.cisco.com/document/69281/asa-using-packet-capture-troubleshoot-asa-firewall-configuration-and-scenarios
Please don't forget to rate and mark as correct the helpful Post!
David Castro,
brianwilliams99
Use the Packet Capture wizard. After you stop your capture, there is a button to "Save Captures" that will bring up another box asking for the save type as "Text" or "PCAP". Save it as a PCAP then open it with Wireshark.
If this is not what you are wanting, let us know.
Also, See this link, it may help.
http://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/118097-configure-asa-00.html
Brian W
Ifrederick313
Create your capture
enter the following command...
https://X.X.X.X/capture/testcap/pcap
Where X is the IP Address of the inside interface
