asa failover
lkadlik
I have just taken over the manangement of this.  From what i understand failover has never been tested but the config looks right. I was hoping someone could take a look and confirm my thought.
interface GigabitEthernet0/0
nameif External-AN
security-level 0
ip address xx.xx.xx.xx  255.255.255.192 standby xx.xx.xx.xx
interface GigabitEthernet0/1
description LAN/STATE Failover Interface
interface GigabitEthernet0/2
nameif Internal-Subnet20
security-level 100
ip address 192.168.20.1 255.255.255.0 standby 192.168.20.2
interface GigabitEthernet0/3
nameif Internal-Subnet5
security-level 100
ip address 192.168.5.1 255.255.255.0 standby 192.168.5.2
fw1# sh failover
Failover On
Failover unit Secondary
Failover LAN Interface: failover GigabitEthernet0/1 (up)
Unit Poll frequency 1 seconds, holdtime 15 seconds
Interface Poll frequency 5 seconds, holdtime 25 seconds
Interface Policy 1
Monitored Interfaces 3 of 250 maximum
failover replication http
Version: Ours 8.2(1), Mate 8.2(1)
Last Failover at: 04:56:27 EDT May 3 2010
        This host: Secondary - Active
                Active time: 8043993 (sec)
                slot 0: ASA5520 hw/sw rev (2.0/8.2(1)) status (Up Sys)
                  Interface External-AN (xx.xx.xx.xx): Normal
                  Interface Internal-Subnet20 (192.168.20.1): Normal
                  Interface Internal-Subnet5 (192.168.5.1): Normal
                  Interface management (0.0.0.0): Link Down (Not-Monitored)
                slot 1: empty
        Other host: Primary - Standby Ready
                Active time: 0 (sec)
                  Interface Internal-Subnet20 (192.168.20.2): Normal
                  Interface Internal-Subnet5 (192.168.5.2): Normal
                  Interface management (0.0.0.0): Normal (Not-Monitored)
                slot 1: empty
Stateful Failover Logical Update Statistics
        Link : failover GigabitEthernet0/1 (up)
        Stateful Obj    xmit       xerr       rcv        rerr
        General         36833939   0          3541299    3
        sys cmd         1278322    0          1278322    0
        up time         0          0          0          0
        RPC services    0          0          0          0
        TCP conn        20760464   0          759190     1
        UDP conn        12738239   0          1267238    2
        ARP tbl         2048444    0          236063     0
        Xlate_Timeout   0          0          0          0
        VPN IKE upd     1756       0          154        0
        VPN IPSEC upd   6684       0          332        0
        VPN CTCP upd    0          0          0          0
        VPN SDI upd     0          0          0          0
        VPN DHCP upd    0          0          0          0
        SIP Session     30         0          0          0
        Logical Update Queue Information
                        Cur     Max     Total
        Recv Q:         0       17      7292769
        Xmit Q:         0       883     64098245
fw1# sh failover interface
        interface failover GigabitEthernet0/1
                System IP Address: 10.10.10.1 255.255.255.252
                My IP Address    : 10.10.10.2
                Other IP Address : 10.10.10.1
failover lan unit secondary
failover lan interface failover GigabitEthernet0/1
failover link failover GigabitEthernet0/1
failover interface ip failover 10.10.10.1 255.255.255.252 standby 10.10.10.2
primary (currently not active)
fw1# sh fail
fw1# sh failover
Failover On
Failover unit Primary
Interface Policy 1
Last Failover at: 12:16:06 EDT May 3 2010
        This host: Primary - Standby Ready
                slot 1: empty
        Other host: Secondary - Active
                Active time: 8044637 (sec)
                slot 1: empty
        General         1072438    0          27627703   266
        sys cmd         1072438    0          1072438    0
        up time         0          0          0          0
        TCP conn        0          0          15031811   213
        UDP conn        0          0          9467080    53
        ARP tbl         0          0          2048569    0
        VPN IKE upd     0          0          1756       0
        VPN IPSEC upd   0          0          6019       0
        VPN SDI upd     0          0          0          0
        SIP Session     0          0          30         0
                        Cur     Max     Total
        Recv Q:         0       30      54896706
        Xmit Q:         0       1       1072438
fw1#
                My IP Address    : 10.10.10.1
                Other IP Address : 10.10.10.2
firewall conf
failover
failover lan unit primary
Jon Marshall
Yes, looks fine to me and failover must have worked at least once as the active firewall is now the standby.
One point though, when posting configs, outputs from devices if they contain public IPs can you blank them out eg. xx.xx.xx.xx
Jon
Jon Marshall
Jon
