ASA running EIGRP but not exchanging routes with cisco 4900-M
rays
i have a situation where we have an ASA currently connected to a Cisco 3800 router
running EIGRP and everything works fine, i.e. eigrp neighbour is formed
and routes exchanged.
I need to move the ASA from the 3800 to our new data centre and connect it to a Cisco 4900-M running EIGRP.
I reconfigured the ASA to the new IP addressing scheme (to match the 4900-M) and included the new network statement in EIGRP.
I cabled the ASA to the 4900-M. Interfaces came up and EIGRP neighbour was formed. However, no routes were exchanged between devices. From the 4900 i could ping the ASA interface withou any problems. I debugged EIGRP on the 4900 and did not see anything that would cause them to not exchange routes. I have another device (3800) on the same subnet and the 4900 is able to exchange routes with it as is the ASA. There are no filters applied to the 4900-M or the ASA.
Has anyone seen a similar issue or have any ideas what the problem, could be? I had to back out the change and as soon as i reconfigured the original IP address on the ASA and moved it back to the old network everything worked fine again.
Ray
6 Replies 6
Giuseppe Larosa
Hello Ray,
verify what is the EIGRP router id on the ASA and on the C4900M.
if equal it prevents learning of external EIGRP routes injected by the other device.
if the problem affects also internal routes verify MTU on both devices, there can be a mismatch with the C4900M likely having an higher one.
use sh ip eigrp interface type x/y to verify all EIGRP parameters
Hope to help
Giuseppe
Hi Guiseppe, thanks for you're reply.
The 4900-M does not have a router id configured. Would this cause this problem? The MTU is default 1500. There are no routes exhanged at all between ASA and 4900, either internal or external.
Ray
Hello Ray,
an EIGRP router.-id is chosen even if you don't configure it so this is not an issue.
Do they list each other in the list of neighbors?
sh ip eigrp neigh
if they don't see each other as neighbors there is some basic mismatch or in AS number, or in K parameters or in IP subnet.
Be aware that you cannot build neighborship using secondary ip addresses.
You should use debug commands to get feedback.
debug eigrp neigh
debug eigrp packet
debug ip eigrp notifications
see
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094613.shtml#nc
Hope to help
Giuseppe
Hi Guiseppe,
i stated previously that I do form an neighbour adjacency. Therefore my K values, MTU etc.. are correct (or else i would not have formed an adjacency).
I am not using secondary addresses. I debugged eigrp and did not see any indications that there was a problem.... very strange.
Ray
I have seen similar issue before but only when network types does not match!
Can you post config..
I had same problem in ASA8.6, but resolved.
Kindly find the EIGRP specific configuration
Interface configuration
interface GigabitEthernet0/0
description Links to WAN Router
nameif OUTSIDE
security-level 50
ip address 10.1.1.4 255.255.255.192 standby 10.1.1.5
summary-address eigrp 100 10.1.0.0 255.255.0.0 1
Eigrp Protocol Confiuration
access-list eigrpACL_FR standard permit any
router eigrp 100
distribute-list eigrpACL_FR in interface OUTSIDE
neighbor 10.1.1.3 interface OUTSIDE
neighbor 10.1.1.2 interface OUTSIDE
network 10.1.1.0 255.255.255.192
redistribute connected
redistribute static
Bhanu.
Note : If it resolves your issue flag it as resolved.
