HSRP between 2 routers with VRRP
ohareka70
Level 3
Level 3
I have 2 routers which sit outside my network that i want to connect directly into the firewall. CPE Router 1 is the active router and CPE Router 2 is the secondary. I have HSRP installed between CPE Router 1 and CPE Router 2. CPE Router 1, CPE Router 2 and the HSRP ip addresses are all on the same subnet. They will both talk to the same servers inside my firewall.
Do i need to have VRRP on the firewall to make this scenario work?  or will i need a switch between the firewall and the 2 x Routers
Q.  Whats the best way to do this?  I have been given some advice that i should disconnect the 2 CPE Routers from the Firewall, and place a Network Switch / VLAN a segment to use for the connection between the Firewall and the 2 CPE devices.
ravikantt
HI Kevin,
there should be L2 connectivity between HSRP peers, which is missing over here.
Plus, you can't  make inter-work HSRP on router side & VRRP on firewall side.
option 1: Get direct link betwwen CPE 1 & CPE 2
option 2: Use L2 switch & CPE1 & CPE2 via this
for HSRP, VRRP; you have chosse one of the option & recommeded is option 2 (although it'd involve little more cost)
but will in tshoot, if anything goes wroung.
Cheers
Ashok
ravikantt
HI Kevin,
Cheers
Ashok
Thanks for your help.  I plugged the two routers into a switch which then plugged into the firewall and HSRP works fine.
Cheers
Kevin
