Tunnel is UP but protocol is down, while performing GRE tunneling
prabinchand
NOTE: PoC is attached below
R2 INTERFACE:
Interface                   IP-Address                    OK?           Method            Status                              Protocol
FastEthernet0/0        2.2.2.2                           YES           manual             up                                   up
FastEthernet0/1        192.168.20.1                 YES           manual             up up
FastEthernet1/0        unassigned                     YES           unset              administratively down       down
FastEthernet1/1        unassigned                     YES           manual           up                                    up
Tunnel1                    172.16.10.1                    YES          manual            up                                   down
R3 INTERFACE:
FastEthernet0/0      1.1.1.2                           YES                manual         up                                 up
FastEthernet0/1      192.168.10.1                 YES                manual         up                                 up
FastEthernet1/1      unassigned                     YES               unset            administratively down    down
Tunnel1                  172.16.10.2                   YES                manual         up                                  down
CONFIGURATION
R1:
redundancy
ip tcp synwait-time 5
interface FastEthernet0/0
ip address 1.1.1.1 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/1
ip address 2.2.2.1 255.255.255.252
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 192.168.10.0 255.255.255.0 1.1.1.2
ip route 192.168.20.0 255.255.255.0 2.2.2.2
nls resp-timeout 1
cpd cr-id 1
no cdp log mismatch duplex
control-plane
R2:
redundancy
interface Tunnel1
ip address 172.16.10.1 255.255.255.0
tunnel source FastEthernet0/0
tunnel destination 1.1.1.2
tunnel key 1111
ip address 2.2.2.2 255.255.255.252
duplex auto
speed auto
ip address 192.168.20.1 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
duplex auto
speed auto
no ip http server
ip route 192.168.10.0 255.255.255.0 172.16.10.2
nls resp-timeout 1
cpd cr-id 1
control-plane
R3:
redundancy
interface Tunnel1
ip address 172.16.10.2 255.255.255.0
tunnel destination 2.2.2.2
tunnel key 1111
ip address 1.1.1.2 255.255.255.252
duplex auto
speed auto
ip address 192.168.10.1 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip http server
ip route 192.168.20.0 255.255.255.0 172.16.10.1
nls resp-timeout 1
cpd cr-id 1
control-plane
2 Accepted Solutions
balaji.bandi
how is your network look like, as per the information you have R1 between R2 and R3 (this is my guess)
Do you have reachability between R2 to R3 ?
add static route in R2
ip route 0.0.0.0 0.0.0.0  1.1.1.1
add static route in R3
ip route 0.0.0.0 0.0.0.0  2.2.2.1
BB
add the static routes marked in bold:
R1:
redundancy
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
duplex auto
speed auto
no ip http server
nls resp-timeout 1
cpd cr-id 1
control-plane
R2:
redundancy
interface Tunnel1
tunnel key 1111
duplex auto
speed auto
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
duplex auto
speed auto
no ip http server
--> ip route 1.1.1.0 255.255.255.252 2.2.2.1
nls resp-timeout 1
cpd cr-id 1
control-plane
R3:
redundancy
interface Tunnel1
tunnel key 1111
duplex auto
speed auto
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip http server
--> ip route 2.2.2.0 255.255.255.252 1.1.1.1
nls resp-timeout 1
cpd cr-id 1
control-plane
8 Replies 8
balaji.bandi
BB
HELLO SIR,
please help me,
i am stuck on same problem from more than 1 week..
here's the link
https://community.cisco.com/t5/routing/how-to-tweak-path-when-1-tunnel-has-2-nhs-using-eigrp/td-p/4514493
HELLO SIR,
please help me,
i am stuck on same problem from more than 1 week.. no one is reply my query
here's the link
@prabinchand @balaji.bandi
I could be wrong, but this doesn't look right:
R2 has 2.2.2.1 as the next hop, not 1.1.1.1
duplex auto
speed auto
and R3 has 1.1.1.1 as the next hop, not 2.2.2.1
duplex auto
speed auto
Or maybe I am reading it the wrong way...
May be other way around, since i do not see how these connected as mentioned in reply.
But bottom line is routing not correct. that fix his problem, hope he got that now i guess.
BB
@balaji.bandi No worries, I was just wondering what test equipment you are working on, and how you got static default routes to work with next hops that are not directly connected...next hops that are not really next hops so to speak.
R1:
redundancy
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
duplex auto
speed auto
no ip http server
nls resp-timeout 1
cpd cr-id 1
control-plane
R2:
redundancy
interface Tunnel1
tunnel key 1111
duplex auto
speed auto
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
duplex auto
speed auto
no ip http server
nls resp-timeout 1
cpd cr-id 1
control-plane
R3:
redundancy
interface Tunnel1
tunnel key 1111
duplex auto
speed auto
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip http server
nls resp-timeout 1
cpd cr-id 1
control-plane
HELLO SIR,
please help me,
i am stuck on same problem from more than 1 week.. no one is replying my query
here's the link
