Asking for help interpreting an image from my CCNA2 class
VillaC12
Hello. I am nearing the end of my CCNA 2 class, and I am on the routing concepts chapter.
This image was on part of the module, and I cannot for the life of me interpret what it is trying to tell me. It has no key to go along with what the numbers mean.
I understand that they are entrys on the routing table, and from what I can tell it is the output you might get from the command
R1# show IP route.
I apologize if similar questions have been asked before, or if this is a silly question with a really obvious answer, but I am not really sure what to search to get an answer on how to interpret this image. Thank you for the help
2 Accepted Solutions
ammahend
this routing table entry indicates that traffic destined for the
10.0.4.0/24 network
should be sent to the next-hop
IP address 10.0.3.2
via the Serial0/1/1 interface, using a OSPF routing protocol with a metric of 110 and a cost of 50. The entry was last updated  13 minutes, and 29 seconds ago.
its same logic for IPv4 or IPv6
-hope this helps-
"Metric of 110 (This has not been discussed in my class, i am not sure what this means)"
- no, this is administrative distance, in short AD, it tells how believable is this route based on Cisco pre-defined scale of connected, static routes and routing protocols (see scale map ). Any static routes have AD of 1 and are better then OSPF AD 110, Lower number is better, all directly connected routes are the best with AD of 0
Yes, 4- Cost or metric 50 - this is OSFP cost or metric for this route/network at this router.
5 and 7 tells u how to reach that network, what is next hop IP or exit interface.
in short, network xyz is OSPF route with cost 50 that you can reach via x IP or via serial interface xyx
Regards, ML
**Please Rate All Helpful Responses **
ammahend
10.0.4.0/24 network
IP address 10.0.3.2
-hope this helps-
Thank you! If I am understanding this right,
1- OSPF routing protocol
2- Designates what traffic it will route
3- Metric of 110 (This has not been discussed in my class, i am not sure what this means)
4- Cost of 50 (Also has not been discussed)
5- Next hop destination for the traffic designated in 2
6- When the entry was last updated
7- The interface that this route is routing on
Regards, ML
