ASR 1000 ERSPAN
Pedro Morais
Hello All,
When trying to configure ERSPAN on a ASR1006, I'm not getting any traffic on the destination port. ERSPAN flavour is LOCAL SPAN, as described in:
http://www.cisco.com/en/US/docs/ios-xml/ios/lanswitch/configuration/xe-3s/lnsw-conf-erspan.html#GUID-4FF72FB4-CDC4-40CC-AA25-E32C8CE58E95
Configuration used, is the following:
monitor session 1 type erspan-source
no shut
source interface GigabitEthernet0/0/2
destination
erspan-id 10
ip address 10.10.10.1
origin ip address 10.10.0.1
monitor session 2 type erspan-destination
no shut
destination interface GigabitEthernet0/0/3
source
  erspan-id 10
Output from “show monitor detail”:
ASR1K_1#sh monitor detail
Session 1
Type                   : ERSPAN Source Session
Status                 : Admin Enabled
Description           : -
Source Ports           :
   RX Only           : None
   TX Only           : None
   Both               : Gi0/0/2
Source VLANs           :
   RX Only           : None
   TX Only           : None
   Both               : None
Destination Ports     : None
Filter VLANs           : None
Source IP Address     : None
Source IP VRF          : None
Source ERSPAN ID       : None
Destination IP Address : 10.10.10.1
Destination IP VRF     : None
Destination ERSPAN ID : 10
Origin IP Address     : 10.10.0.1
IP QOS PREC           : 0
IP TTL                 : 255
Session 2
Type                  : ERSPAN Destination Session
Description           : -
Source Ports           :
   RX Only           : None
   TX Only           : None
   Both               : None
Source VLANs           :
   RX Only           : None
   TX Only           : None
   Both               : None
Destination Ports     : Gi0/0/3
Filter VLANs           : None
Source IP Address     : 10.10.0.1
Source ERSPAN ID       : 10
Destination IP Address : None
Destination ERSPAN ID : None
Origin IP Address     : None
IP QOS PREC           : 0
IP TTL                 : 255
Apparently everything is configured in the proper way, however I’m not getting any traffic in the destination port. Also I’ve noticed the following in the details from ‘Session 1’:
That doesn’t make much sense to me.
Could anyone help me understand how to configure Local SPAN using ERSPAN?
Pedro
Edison Ortiz
The source session will have information where to send it (that's the destination IP)
While the destination session will have information from the source.
It looks normal - did you configure 10.10.10.1 as the loopback on this router?
That's a requirement.
Hi Edison,
I changed the monitor config to match the IP address of loopback0 that I have in this router:
ASR1K_1#sh ip int brief | i Loop
Loopback0              172.25.200.10   YES NVRAM  up                    up
Loopback100            192.168.200.21  YES manual up                    up
ASR1K_1#
ASR1K_1#sh run | b monitor
source interface Gi0/0/2
destination
  erspan-id 10
  ip address 172.25.200.10
destination interface Gi0/0/3
source
  erspan-id 10
end
However still not working. When I check the destination interface (Gi0/0/3) stats:
ASR1K_1#sh interfaces stats
GigabitEthernet0/0/0
          Switching path    Pkts In   Chars In   Pkts Out  Chars Out
               Processor      78613  721352514     203867  738528166
             Route cache          0          0          0          0
       Distributed cache     395669  747596509     389077  753024214
                   Total     474282 1468949023     592944 1491552380
Interface GigabitEthernet0/0/1 is disabled
               Processor      26765    1712960      26745    1711680
             Route cache          0          0          0          0
       Distributed cache      26768    1713152      27258    2193668
                   Total      53533    3426112      54003    3905348
               Processor          9        540          0          0
             Route cache          0          0          0          0
       Distributed cache       4980    1040936          0          0
                   Total       4989    1041476          0          0
Any idea?
Pedro
Hi, Change IP 10.10.10.1 to 172.25.200.10 in your ERSPAN  source and destination session. Both session must have same IP in ERSPAN when you are using it as local span.
Hello
The destination address, is that of a routed or svi interface, quite sure the destination needs to be the ip address of the svi to which the destination physical port resides in.
Kind Regards
Paul
