ASR-1002-x IOS upgrade issue
ammar-taha
hello
we have cisco ASR1002-X and we try to upgrade it to
asr1002x-universalk9.16.06.07.SPA
after we restart the router it enter in restarting loop and show this messages
now i can't do anything to router
Initializing Hardware ...
System integrity status: 00000610
System Bootstrap, Version 16.2(1r), RELEASE SOFTWARE (fc1)
Copyright (c) 1994-2016 by cisco Systems, Inc.
Current image running: Boot ROM1
Last reset cause: LocalSoft
SPI Flash 4KB Descriptor Area Checksum = 0x6f5a0db2
ASR1002-X platform with 4194304 Kbytes of main memory
File size is 0x280cbc94
Located asr1002x-universalk9.16.06.07.SPA.bin
Image size 671923348 inode num 16, bks cnt 164044 blk size 8*512
Boot image size = 671923348 (0x280cbc94) bytes
ROM:RSA Self Test Passed
ROM:Sha512 Self Test Passed
Package header rev 1 structure detected
Calculating SHA-1 hash...done
validate_package_cs: SHA-1 hash:
        calculated e5dc3503:e4bee5d8:48560ffb:59a05ee4:9d09ba23
        expected   e5dc3503:e4bee5d8:48560ffb:59a05ee4:9d09ba23
Validating main package signatures
RSA Signed RELEASE Image Signature Verification Successful.
Image validated
>>> Boot Failed - pulling status and logs:
? localhost
    State: initializing
     Jobs: 2 queued
   Failed: 0 units
    Since: Wed 2022-05-18 13:22:43 Universal; 1min 29s ago
   CGroup: /
           tqinit.scope
           x mq1 /init
           mqsystem.slice
             tqsystemd-journald.service
             x mq179 /lib/systemd/systemd-journald
             tqsystemd-udevd.service
             x mq188 /lib/systemd/systemd-udevd
             mqreport_fails.service
               tq264 /bin/bash -c systemctl status $(systemctl --failed --no-legend | cut -d' ' -f1 ) -l -n 100 -o short-monotonic --no-pager;   sleep 5 # delay to let slow console flush
               mq268 systemctl status -l -n 100 -o short-monotonic --no-pager
 You need to get in rommon mode and try to at least start from previous version.
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/install/guide/asr1routers/asr-1000-series-hig/asr-hig-tbl.html
Press the Break key or send a Break from the console terminal. If Break is enabled, the router enters the ROM monitor, indicated by the ROM monitor prompt (rommon1>).
Leo Laohoo
This is the culprit. Let me explain:
1.  Router is getting upgraded to 16.6.X but the ROMMON is still 16.2(1r).
2.  Cisco hides the ROMMON compatibility matrix for ISR 4000 and ASR 1000.
3.  If I use the ROMMON Compatibility Matrix for the ISR 1000, for firmware version 16.6.X the router should have a ROMMON version of 16.9(4r) or newer.
Please take the time to read this:  Cisco ISR & ASR 1k Routers: IOS-XE/Firmware Upgrade (Install Mode)
This document will provide the correct guidance on how to upgrade the ROMMON, upgrade the firmware in Install Mode (recommended) and any "gotchas" that you need to look out for.
Hope this helps.
