ASR 9001 MIB OID values?
Andrew WEISS
Beginner
Beginner
We're in the process of testing a number of ASR9001 (IOS-XR 5.1.2) that will serve as replacement route-reflectors, however we've been having the hardest time identifying the correct MIB OID values for SNMP monitoring via Nagios.
We have downloaded a number of the MIBs, however the OID values indicated within do not seem to appy to our device.  For Example: the ENVMON is not 1.3.6.1.4.1.9.9.13 as indicated within the MIB.
Is anyone aware of a central repository that contains the ASR 9001 OID values and a description of what they do?
Were not looking to do anything fancy at this point, however we would like to know if the power supplies are both active and the fans are running as well as some details regarding the CPU and memory usage.
Kind regards,
Andrew
Nikhil Kapoor
Hi Andrew,
Below links may help you in locating the MIB (s).
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&step=2
http://www.cisco.com/public/sw-center/netmgmt/cmtk/mibs.shtml
http://tools.cisco.com/ITDIT/MIBS/servlet/index
HTH,
Nikhil
Recognize Your Peers
