ASR 901 no Internet On LAN
pavithran
My Configuration is below I'm able to ping websites inside the router. But unable to browse the internet on Lan IP address.
Building configuration...
Current configuration: 2680 bytes
! Last configuration change at 11:59:53 UTC Sun Mar 24 2019
! NVRAM config last updated at 10:46:41 UTC Sun Mar 24 2019
version 15.4
service config
asr901-platf-multi-nni-cfm
hostname ROUTER
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp pool vois_pool
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
dns-server 8.8.8.8 8.8.4.4
lease 0 1
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ipv6 cef
l3-over-l2 flush buffers
spanning-tree mode pvst
license udi pid A901-6CZ-F-D sn CAT1832U26L
license accept end user agreement
license boot level AdvancedMetroIPAccess
interface GigabitEthernet0/0
no ip address
negotiation auto
service instance 1 ethernet
encapsulation untagged
bridge-domain 1
interface GigabitEthernet0/1
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/2
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/3
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/4
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/5
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/6
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/7
no ip address
negotiation auto
service instance 8 ethernet
bridge-domain 8
interface GigabitEthernet0/8
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/9
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/10
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/11
no ip address
shutdown
negotiation auto
interface TenGigabitEthernet0/0
no ip address
shutdown
interface TenGigabitEthernet0/1
no ip address
shutdown
interface FastEthernet0/0
no ip address
shutdown
interface Vlan1
ip address 192.168.20.1 255.255.255.0
ip nat inside
interface Vlan8
ip address 10.70.70.254 255.255.255.0
ip nat outside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.70.70.1
access-list 1 permit 192.168.20.0 0.0.0.255
control-plane
environment monitor
exception crashinfo buffersize 128
end
25 Replies 25
Jon Marshall
ip nat inside source list 1 interface vlan 8 overload
Jon
Hi Jon,
I tried with the "ip nat inside source list 1 interface VLAN 8 overload" with no success. Still no Internet on LAN
Are you able to successfully ping to 8.8.8.8 from the router console using the source VLAN 8? Which is a device "10.70.70.1"?
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
VOIS_ROUTER#ping 8.8.8.8 source vlan 8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Packet sent with a source address of 10.70.70.254
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/20/20 ms
Yes I'm able to ping
which physical interface(s) on the ASR are your clients connected to ?
Clients are connected on interface gi0/0 and the WAN port is gi0/7.
try and change:
no ip address
negotiation auto
bridge-domain 1
to
no ip address
negotiation auto
encapsulation dot1q 1 untagged
bridge-domain 1
Would you post the updated config? Also would you post output of the commands show ip route and show arp?
Rick
Rick
VOIS_ROUTER#show runn
Current configuration : 2892 bytes
! Last configuration change at 15:55:18 UTC Mon Mar 25 2019
! NVRAM config last updated at 15:54:29 UTC Mon Mar 25 2019
version 15.4
hostname VOIS_ROUTER
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
lease 0 1
no ipv6 cef
no ip address
negotiation auto
bridge-domain 1
no ip address
negotiation auto
service instance 2 ethernet
bridge-domain 2
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
negotiation auto
bridge-domain 8
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
interface Vlan1
interface Vlan8
ip address 10.70.70.254 255.255.250.0
ip nat outside
ip nat inside source list 1 interface Vlan8 overload
no ip http server
control-plane
environment monitor
end
VOIS_ROUTER#
VOIS_ROUTER#show arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 10.70.70.1 0 6c3b.6b60.1866 ARPA Vlan8
Internet 10.70.70.3 0 e48d.8c6d.6648 ARPA Vlan8
Internet 10.70.70.254 - f07f.068a.e710 ARPA Vlan8
Internet 192.168.20.1 - f07f.068a.e710 ARPA Vlan1
Internet 192.168.20.2 0 f8a9.639b.2d64 ARPA Vlan1
VOIS_ROUTER#
VOIS_ROUTER#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override
Gateway of last resort is 10.70.70.1 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 10.70.70.1
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.70.70.0/24 is directly connected, Vlan8
L 10.70.70.254/32 is directly connected, Vlan8
192.168.20.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.20.0/24 is directly connected, Vlan1
L 192.168.20.1/32 is directly connected, Vlan1
VOIS_ROUTER#
Tried with encapsulation dot1q 1 untagged, but the client cannot get the IP address at all.
Can you try with:
no ip nat inside source list 1 interface Vlan8 overload
Ip access-list standard 2
permit any
ip nat inside source list 2 interface vlan 8 overload
Deepak Kumar
Deepak Kumar,
Hi Deepak,
As per the suggestion, I've changed the configuration as following, Still, it is not working.
ip nat inside source list 2 interface Vlan8 overload
no ip http server
access-list 2 permit any
Let do more tshoot on client machine:
Open CMD and run a command:
1. Ipconfig /all
2. route -4 print
3. tracert 8.8.8.8
Share all logs with us.
Deepak Kumar
Deepak Kumar,
One more point:
interface Vlan1
IP NAT Inside
I think you removed this command. And please verify that 10.10.10.71 is the next-hop address for WAN (default route).
Deepak Kumar
Deepak Kumar,
small detail maybe, but try and add:
ip dhcp excluded-address 192.168.20.1
to your configuration...
