WAN routing issues---need some help please!
dstriplin1
I'm trying to connect a basic comcast modem only (not modem/router combo) to my 2921 router and have it give internet access to my lab. Any help is greatly appreciated!
Here is my current setup and topology
Internet- assigned via dhcp from Comast
Network LAN 10.0.1.0/24
PC address - 10.0.1.22
GW- 10.0.1.1
Here are the outputs from sh run and show ip int
Lab2921#show run
Building configuration...
Current configuration : 2452 bytes
! Last configuration change at 15:06:44 UTC Tue Mar 26 2019
version 15.7
no parser cache
service timestamps debug uptime
service timestamps log uptime
hostname Lab2921
boot-start-marker
boot-end-marker
logging userinfo
enable secret 5 $1$aP02$GoblxTJ6F3.kaw7Soxvr50
no aaa new-model
ip dhcp excluded-address 10.0.1.1
ip dhcp excluded-address 10.0.1.2
ip dhcp excluded-address 10.0.1.177
ip dhcp excluded-address 10.0.1.169
ip dhcp excluded-address 10.0.1.100 10.0.1.254
ip dhcp excluded-address 10.0.1.1 10.0.1.5
ip dhcp pool InsideDHCP
import all
network 10.0.1.0 255.255.255.0
default-router 10.0.1.1
dns-server 8.8.8.8 8.8.4.4
class any
ip dhcp class any
no ip domain lookup
ip cef
no ipv6 cef
vty-async
license udi pid CISCO2921/K9 sn FTX1728AHR1
redundancy
no cdp run
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Facing the ISP (the WAN)
ip address dhcp
ip nat inside
ip virtual-reassembly in
no ip route-cache
duplex auto
speed auto
no cdp enable
bridge-group 59
bridge-group 59 spanning-disabled
interface GigabitEthernet0/1
description Facing my LAN (the LAN)
ip address 10.0.1.1 255.255.255.0
ip nat outside
no ip route-cache cef
duplex auto
speed auto
no cdp enable
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip default-gateway 10.0.1.1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
access-list 1 permit 10.0.1.0 0.0.0.255
access-list 102 permit ip 10.0.1.0 0.0.0.255 any
control-plane
vstack
banner motd ^C
AUTHORIZED ACCESS ONLY
^C
line con 0
exec-timeout 0 0
password AlphaBravo9
login
stopbits 1
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
exec-timeout 120 0
login local
length 0
transport input none
scheduler max-task-time 5000
scheduler allocate 20000 1000
end
SHow IP int
Lab2921#show ip int
Embedded-Service-Engine0/0 is administratively down, line protocol is down
Internet protocol processing disabled
GigabitEthernet0/0 is down, line protocol is down
GigabitEthernet0/1 is up, line protocol is up
Internet address is 10.0.1.1/24
Broadcast address is 255.255.255.255
Address determined by setup command
MTU is 1500 bytes
Helper address is not set
Directed broadcast forwarding is disabled
Outgoing access list is not set
Inbound access list is not set
Proxy ARP is enabled
Local Proxy ARP is disabled
Security level is default
Split horizon is enabled
ICMP redirects are always sent
ICMP unreachables are always sent
ICMP mask replies are never sent
IP fast switching is enabled
IP fast switching on the same interface is disabled
IP Flow switching is disabled
IP CEF switching is disabled
IP Null turbo vector
IP multicast fast switching is enabled
IP multicast distributed fast switching is disabled
IP route-cache flags are Fast, No CEF
Router Discovery is disabled
IP output packet accounting is disabled
IP access violation accounting is disabled
TCP/IP header compression is disabled
RTP/IP header compression is disabled
Policy routing is disabled
Network address translation is enabled, interface in domain outside
BGP Policy Mapping is disabled
Input features: Common Flow Table, Stateful Inspection, Virtual Fragment Reassembly, Virtual Fragment Reassembly After IPSec Decryption, NAT Outside, MCI Check
Output features: Post-routing NAT Outside, Common Flow Table, Stateful Inspection, NAT ALG proxy
IPv4 WCCP Redirect outbound is disabled
IPv4 WCCP Redirect inbound is disabled
IPv4 WCCP Redirect exclude is disabled
GigabitEthernet0/2 is administratively down, line protocol is down
NVI0 is up, line protocol is up
Internet address will be negotiated using IPCP
MTU is 1514 bytes
IP fast switching is disabled
IP route-cache flags are Fast, CEF
Network address translation is disabled
Input features: MCI Check
Output features: Post-routing NAT NVI Output
2 Accepted Solutions
In the DHCP pool in your router config add the statement default-router 10.0.1.1
If you look at some of the early posts in this discussion you will find it there. Somewhere along the line it was removed. Now you need to put it back.
Rick
Rick
It is looking good to me. I think now you are good to go.
Rick
Rick
47 Replies 47
balaji.bandi
GigabitEthernet0/0 is down, line protocol is down  <-- check this why down ?
As per the config - check the interface config and change accordingly, high level below
ip address dhcp
ip nat inside   << ---if this is outside  ip nat outside
no ip route-cache
duplex auto
speed auto
no cdp enable
bridge-group 59
ip nat outside   <-- << ---if this is  inside  ip nat inside
duplex auto
speed auto
no cdp enable
BB
BB,
I tried and I still don't get internet access.  Here is the latest show run
Lab2921#show run
! Last configuration change at 18:25:50 UTC Tue Mar 26 2019
version 15.7
no parser cache
hostname Lab2921
boot-start-marker
boot-end-marker
logging userinfo
no aaa new-model
import all
class any
ip dhcp class any
no ip domain lookup
ip cef
no ipv6 cef
vty-async
redundancy
no cdp run
no ip address
shutdown
ip address dhcp
ip nat inside
no ip route-cache
duplex auto
speed auto
no cdp enable
bridge-group 59
ip nat outside
duplex auto
speed auto
no cdp enable
no ip address
shutdown
duplex auto
speed auto
no ip http server
control-plane
vstack
banner motd ^C
^C
line con 0
exec-timeout 0 0
login
stopbits 1
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
exec-timeout 120 0
login local
length 0
end
i do not see the changes in your config. make sure you change the out side and inside nat.
check the interface also down ?
BB
make sure your configuration looks EXACTLY like below (line by line). You still have the outside and inside NAT interfaces switched the wrong way. Also, there is a bridge group configured, delete that as well.
Lab2921#show run
version 15.7
no parser cache
hostname Lab2921
boot-start-marker
boot-end-marker
logging userinfo
no aaa new-model
import all
class any
ip dhcp class any
no ip domain lookup
ip cef
no ipv6 cef
vty-async
redundancy
no cdp run
no ip address
shutdown
ip address dhcp
ip nat outside
no ip route-cache
duplex auto
speed auto
no cdp enable
ip nat inside
duplex auto
speed auto
no cdp enable
no ip address
shutdown
duplex auto
speed auto
no ip http server
control-plane
vstack
banner motd ^C
^C
line con 0
exec-timeout 0 0
login
stopbits 1
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
exec-timeout 120 0
login local
length 0
end
Thanks for your help. What is odd is everytime I change the nat type by doing the following commands, it doesn't seem to change.  After i change the interface commands, i exit out of config and do copy running-config startup-config and then after doing a show run it still shows the nat type as if I haven't entered the command.  Here is the log from the change as well as the show run again.  Any idea why this could be happening?
Lab2921#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Lab2921(config)#int gig0/0
Lab2921(config-if)#ip nat outside
% Interface is inside enabled.
Lab2921(config-if)#exit
Lab2921(config)#int gig0/1
Lab2921(config-if)#ip nat inside
% Interface is outside enabled.
Lab2921(config)#ip nat inside source list 1 interface gig0/0 overload
Lab2921(config)#exit
Lab2921#cop
06:14:05: %SYS-5-CONFIG_I: Configured from console by console
Lab2921#copy ru
Lab2921#copy running-config st
Lab2921#copy running-config startup-config
Destination filename [startup-config]?
[OK]
Lab2921#show run
! Last configuration change at 18:33:56 UTC Tue Mar 26 2019
version 15.7
no parser cache
hostname Lab2921
boot-start-marker
boot-end-marker
logging userinfo
no aaa new-model
import all
class any
ip dhcp class any
no ip domain lookup
ip cef
no ipv6 cef
vty-async
redundancy
no cdp run
no ip address
shutdown
ip address dhcp
ip nat inside
no ip route-cache
duplex auto
speed auto
no cdp enable
bridge-group 59
Lab2921#conf t
Lab2921(config-if)#^Z
Lab2921#so
06:14:44: %SYS-5-CONFIG_I: Configured from console by consocopy
Lab2921#copy runn
[OK]
Lab2921#show run
! Last configuration change at 18:34:34 UTC Tue Mar 26 2019
version 15.7
no parser cache
hostname Lab2921
boot-start-marker
boot-end-marker
logging userinfo
no aaa new-model
import all
class any
ip dhcp class any
no ip domain lookup
ip cef
no ipv6 cef
vty-async
redundancy
no cdp run
no ip address
shutdown
ip address dhcp
ip nat inside
no ip route-cache
duplex auto
speed auto
no cdp enable
bridge-group 59
ip nat outside
duplex auto
speed auto
no cdp enable
no ip address
shutdown
duplex auto
speed auto
no ip http server
control-plane
vstack
banner motd ^C
^C
line con 0
exec-timeout 0 0
login
stopbits 1
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
exec-timeout 120 0
login local
length 0
end
Lab2921#
First try  remove with no ip nat inside and then ip nat outside.
config t
no ip nat inside
no ip nat outside
ip nat outside
ip nat inside
end
wr
post show run
BB
Gave it a shot, here are the results.
Lab2921#conf t
Lab2921(config-if)#no ip nat inside
Lab2921(config-if)#
06:39:01: %IP_VFR-7-FEATURE_STATUS_IN: VFR(in) is being used by other features. Will be disabled when no other feature needs VFR support on interface GigabitEthernet0/0
Lab2921(config-if)#no ip nat outside
Lab2921(config-if)#
06:40:12: %IP_VFR-7-FEATURE_STATUS_IN: VFR(in) is being used by other features. Will be disabled when no other feature needs VFR support on interface GigabitEthernet0/1
Lab2921(config)#end
Lab2921#
06:40:54: %SYS-5-CONFIG_I: Configured from console by console
Lab2921#wr
[OK]
Lab2921#show run
! Last configuration change at 19:00:44 UTC Tue Mar 26 2019
version 15.7
no parser cache
hostname Lab2921
boot-start-marker
boot-end-marker
logging userinfo
no aaa new-model
import all
class any
ip dhcp class any
no ip domain lookup
ip cef
no ipv6 cef
vty-async
redundancy
no cdp run
no ip address
shutdown
ip address dhcp
ip nat outside
no ip route-cache
duplex auto
speed auto
no cdp enable
bridge-group 59
ip nat inside
duplex auto
speed auto
no cdp enable
no ip address
shutdown
duplex auto
speed auto
no ip http server
control-plane
vstack
banner motd ^C
^C
line con 0
exec-timeout 0 0
login
stopbits 1
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
exec-timeout 120 0
login local
length 0
end
what is the results, are you able to test and working  as you expected ?
you bridge config still, need to clean up
no bridge-group 59
nobridge-group 59 spanning-disabled
BB
Ok.  Cleaned that up.  Here is the output
Lab2921#show run
Current configuration : 2400 bytes
! Last configuration change at 19:08:02 UTC Tue Mar 26 2019
version 15.7
no parser cache
hostname Lab2921
boot-start-marker
boot-end-marker
logging userinfo
no aaa new-model
import all
class any
ip dhcp class any
no ip domain lookup
ip cef
no ipv6 cef
vty-async
redundancy
no cdp run
no ip address
shutdown
ip address dhcp
ip nat outside
no ip route-cache
duplex auto
speed auto
no cdp enable
ip nat inside
duplex auto
speed auto
no cdp enable
no ip address
shutdown
duplex auto
speed auto
no ip http server
control-plane
vstack
banner motd ^C
^C
line con 0
exec-timeout 0 0
login
stopbits 1
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
exec-timeout 120 0
login local
length 0
end
what is your tests ? and outcome ?
BB
So after making the changes, I'm still not getting internet access.  Here is the dump after making the changes and confirming I cannot get internet access.
07:18:00: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to up
07:18:01: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to up
07:18:19: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
07:18:20: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to down
07:18:23: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up
07:18:24: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
Lab2921#
Lab2921#show run
version 15.7
no parser cache
hostname Lab2921
boot-start-marker
boot-end-marker
logging userinfo
no aaa new-model
import all
class any
ip dhcp class any
no ip domain lookup
ip cef
no ipv6 cef
vty-async
redundancy
no cdp run
no ip address
shutdown
ip address dhcp
ip nat outside
no ip route-cache
duplex auto
speed auto
no cdp enable
ip nat inside
duplex auto
speed auto
no cdp enable
no ip address
shutdown
duplex auto
speed auto
no ip http server
control-plane
vstack
banner motd ^C
^C
line con 0
exec-timeout 0 0
login
stopbits 1
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
exec-timeout 120 0
login local
length 0
end
Can you post show ip interface brief ?
what is the PC IP address and where it is connected (what port ?)
BB
Sure.  The PC is connected from gig0/1 directly via ethernet.  The address it's giving me on the PC seems fine.... 10.0.1.6 gw 10.0.1.1.
Lab2921#sho ip int br
Embedded-Service-Engine0/0 unassigned YES NVRAM administratively down down
GigabitEthernet0/0 unassigned YES DHCP up up
GigabitEthernet0/1 10.0.1.1 YES manual up up
GigabitEthernet0/2 unassigned YES NVRAM administratively down down
NVI0 unassigned YES unset up up
Lab2921#
Did that help?  Pulling my hair out on this one as things seem to be configured correctly.....
