ASR 901 no Internet On LAN
pavithran
My Configuration is below I'm able to ping websites inside the router. But unable to browse the internet on Lan IP address.
Building configuration...
Current configuration: 2680 bytes
! Last configuration change at 11:59:53 UTC Sun Mar 24 2019
! NVRAM config last updated at 10:46:41 UTC Sun Mar 24 2019
version 15.4
service config
asr901-platf-multi-nni-cfm
hostname ROUTER
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp pool vois_pool
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
dns-server 8.8.8.8 8.8.4.4
lease 0 1
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ipv6 cef
l3-over-l2 flush buffers
spanning-tree mode pvst
license udi pid A901-6CZ-F-D sn CAT1832U26L
license accept end user agreement
license boot level AdvancedMetroIPAccess
interface GigabitEthernet0/0
no ip address
negotiation auto
service instance 1 ethernet
encapsulation untagged
bridge-domain 1
interface GigabitEthernet0/1
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/2
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/3
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/4
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/5
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/6
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/7
no ip address
negotiation auto
service instance 8 ethernet
bridge-domain 8
interface GigabitEthernet0/8
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/9
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/10
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/11
no ip address
shutdown
negotiation auto
interface TenGigabitEthernet0/0
no ip address
shutdown
interface TenGigabitEthernet0/1
no ip address
shutdown
interface FastEthernet0/0
no ip address
shutdown
interface Vlan1
ip address 192.168.20.1 255.255.255.0
ip nat inside
interface Vlan8
ip address 10.70.70.254 255.255.255.0
ip nat outside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.70.70.1
access-list 1 permit 192.168.20.0 0.0.0.255
control-plane
environment monitor
exception crashinfo buffersize 128
end
25 Replies 25
Is it necessary to have IPBase license? I have AdvancedIPMetroAccess License installed in my Router. Is there any relation to my issue?
Which license you have does not have anything to do with this problem. And the license that you have provides more capabilities than the IPBASE license would. If it is still not working then please provide the most current output of show run. We would be looking especially for nat inside on the LAN interface, nat outside on the WAN interface and the command to translate with access list 1 on vlan 8 overload.
Rick
Rick
VOIS_ROUTER#sh runn
Current configuration : 2609 bytes
! No configuration change since last restart
version 15.4
service config
hostname VOIS_ROUTER
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
no ip address
negotiation auto
bridge-domain 1
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
negotiation auto
bridge-domain 8
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
interface Vlan1
ip nat inside
interface Vlan8
ip nat outside
ip nat inside source list 1 interface Vlan8 overload
no ip http server
control-plane
environment monitor
end
Thank you for posting a fresh copy of the config. The address translation seems ok. I do see that both of the interfaces have specified encapsulation untagged  I thought that earlier in the discussion you indicated that this created problems. Please change this and let us know if things work better.
Rick
Rick
Hello
Never I had to use these before but your configuration seems to suggest your using EVC into the ISP  (EVC doc)
After the review of the documentation it looks like your two interfaces are not able to communicate with each to allow traffic to traverse the evc connection - Could you try the following:
Description LAN port
encapsulation dot1q 1-8
bridge-domain 18
Description WAN port
encapsulation dot1q 8
rewrite ingress pop 1 symmetric
bridge-domain 18
Kind Regards
Paul
None is working :(
Can the PC at 192.168.20.2 ping its gateway at 192.168.20.1? Can that PC ping the outside interface at 10.70.70.254?
Rick
Rick
The PC can ping the gateway and the outside interface IP. I'm still surprised with ASR 901, what exactly the problem could be!
Hello
Int vlan 1
ip nat inside < ——- looks like this is missing now!
Kind Regards
Paul
Paul
Yes it is. Good catch.
Rick
Rick
Deepak Kumar
I found that you had missed the NAT configuration.
"ip nat inside source list 1 interface VLAN 8 overwrite"
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
