09-06-2023
05:21 AM
- last edited on
09-10-2023
10:52 PM
by
Translator
Hello guys,
we configured
BDI interfaces
on our ASR 903 and using a
Tengig interface
for bridge domains....
We wonder which speed the
BDI interfaces
use?
Bandwith parameter shows
1000000 Kbit/sec
. but this I think is important for overlaying protocols and has nothing to do with the actual speed right?
How can we check if the BID "uses" the full speed from the
Tengig interface
, anything we need to configure or will the
BDI interfaces
use the full 10Gig?
Config:
interface TenGigabitEthernet0/0/0
description connect wan wansw01 1/4
no ip address
cdp enable
service instance 1 ethernet
encapsulation untagged
l2protocol peer cdp lacp
bridge-domain 1
service instance 3207 ethernet
encapsulation dot1q 3207
rewrite ingress tag pop 1 symmetric
bridge-domain 3207
interface BDI3207
description DC-GWAN-SIG
vrf forwarding gwan
ip address 172.25.82.53 255.255.255.248
nekwz3dcrt01#sh int BDI3207
BDI3207 is up, line protocol is up
Hardware is BDI, address is acf5.e628.2d3f (bia acf5.e628.2d3f)
Description: DC-GWAN-SIG
Internet address is 172.25.82.53/29
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Thanks for your feedback
Rgds
Solved! Go to Solution.
09-06-2023
07:41 AM
- last edited on
09-10-2023
10:59 PM
by
Translator
Hello @andreas.fuchs ,
1000000 Kbit/sec
Your understanding is correct the BDI bandwidth value does not cause traffic rate limiting on the physical
interface tengiga
You may want to change the bandwidth under the
interface BDI
just for documentation purposes
Hope to help
Giuseppe
09-06-2023
05:30 AM
- last edited on
09-10-2023
10:54 PM
by
Translator
can you post
show interface ten 0/0/0
09-06-2023
05:33 AM
- last edited on
09-10-2023
10:56 PM
by
Translator
#sh int TenGigabitEthernet0/0/0
TenGigabitEthernet0/0/0 is up, line protocol is up
Hardware is A900-IMA2Z, address is acf5.e628.2d00 (bia acf5.e628.2d00)
Description: connect wan nekwn1wansw01 1/4
MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 16/255, rxload 16/255
Keepalive set (10 sec)
Full Duplex, 10000Mbps, link type is force-up, media type is 10GBase-SR
output flow-control is unsupported, input flow-control is on
Last input 00:00:57, output 00:00:27, output hang never
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 629755000 bits/sec, 117927 packets/sec
5 minute output rate 634048000 bits/sec, 121061 packets/sec
441836794290 packets input, 281688341404048 bytes, 0 no buffer
Received 10025304 broadcasts (0 IP multicasts)
0 watchdog, 38476179 multicast, 0 pause input
487564168788 packets output, 330754574807756 bytes, 0 underruns
Output 237 broadcasts (0 IP multicasts)
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
09-06-2023
07:41 AM
- last edited on
09-10-2023
10:59 PM
by
Translator
1000000 Kbit/sec
interface tengiga
interface BDI
Hope to help
Giuseppe
09-06-2023
09:17 AM
- last edited on
09-10-2023
11:03 PM
by
Translator
"How can we check if the BDI "uses" the full speed from the
Tengig interface
BDI interfaces
use the full 10Gig?"
In the absence of QoS policies, the scheduler will default to allocating all the available bandwidth of the parent physical interface to the BDI. If you have more than one BDI, and no QoS policies, all BDIs will contend for the physical interface's available bandwidth.
09-06-2023 11:45 PM
Thanks guys, just wanted to confirm if my thoughts are correct.
Cheers
