ASR BVI Problem
Diana Karolina Rojas
Hello community good morning,
We are experiencing troubles with one BVI in our ASR 9006 (IOS version 6.0.2), the BVI is the gateway for a customer and yesterday it didn't work and also generates this log:
LC/0/1/CPU0:Apr 4 12:58:35.419 : fib_mgr[184]: %ROUTING-FIB-3-ASSERT_CTX : BCDLdispatch [ipv4_rib pri=0 #prev_rt=0 #prev_non_rt=0] BCDLtable [0xe0000000 #upd=2 flags=0x8(local)] RTupd [IPv4:default:0xe0000000[0x59d292a4],rib,190.12.108.172/32,flags=0x400808,#paths=1[0x20524e0,0.0.0.0,0x8] ver=1157537829] Leaf [IPv4:default:0xe0000000[0x59d292a4]:aib:190.12.108.172/32[ref:1 proto:ipv4 flags:0x1120001 f2:0x0 src:aib][0x60f95494] [ref:4 pl:607b81b0 proto:ipv4 type:ip lvl:1 buckets:1 slots:1 fixup:0 flags:[o
wner locked, added to (TRUNCATED)
LC/0/1/CPU0:Apr 4 12:58:35.420 : fib_mgr[184]: %ROUTING-FIB-3-ASSERT : FIB internal inconsistency detected: route new 3701 ctx flags 0x1 leaf flag 0x224000 flag2 0x0 leaf IPv4:default:0xe0000000:aib:190.12.108.172/32[src:aib] frs IPv4:aib:flags=0x1:size=28{IPv4:default:0xe0000000[0x59d292a4],aib,190.12.108.172/32,flags=0x224000,#paths=1[0x99c60,0.0.0.0]}[0x59bda0b8] : pkg/bin/fib_mgr : (PID=196716) : -Traceback= f447441 f4474cb 4396f48 439f872 421db0d 4237ef7 4238db1 4239276 421fa35 421fba5 422464e 42249
1e b06b4eb b069514 420(TRUNCATED)
LC/0/0/CPU0:Apr 4 13:04:56.032 : fib_mgr[183]: %ROUTING-FIB-3-PLATF_UPD_FAIL : FIB platform update failed: Obj=DATA_TYPE_LDI_LW[ptr=5e8d7d88,refc=0x3,flags=0x10] Action=MODIFY Proto=ipv4. Cerr='FIB' detected the 'warning' condition 'Invalid argument' : pkg/bin/fib_mgr : (PID=188525) : -Traceback= 1035e950 1035ed4f 426e047 427855d 427be3d 4250fbf 4390155 4399da6 439d16d 421db0d 4237ef7 4238db1 4239276 421fa35 421fba5 422464e
LC/0/0/CPU0:Apr 4 13:04:56.033 : fib_mgr[183]: %ROUTING-FIB-3-PD_FAIL : FIB platform error: fib_leaf_ldi_lw_platform_update 622: PD action MODIFY failed for lw_ldi 0x5e8d7d88 flags 0x10. Shared LDI 0x6a0c403c num_slots 1 num_buckets 1 depth 1 ldi type 3 ldi protocol ipv4 flags 0x2008401 pfx 190.12.108.172/32 : 0x4ff40200 'FIB' detected the 'warning' condition 'Invalid argument' : pkg/bin/fib_mgr : (PID=188525) : -Traceback= 426e136 427855d 427be3d 4250fbf 4390155 4399da6 439d16d 421db0d 4237ef7 4238db1
4239276 421fa35 421fba(TRUNCATED)
LC/0/0/CPU0:Apr 4 13:15:39.814 : fib_mgr[183]: %ROUTING-FIB-3-PLATF_UPD_FAIL : FIB platform update failed: Obj=DATA_TYPE_LDI_LW[ptr=5e7b5da0,refc=0x2,flags=0x8] Action=CREATE Proto=ipv4. Cerr='FIB' detected the 'warning' condition 'Invalid argument' : pkg/bin/fib_mgr : (PID=188525) : -Traceback= 1035e950 1035ed4f 426e047 427855d 427be3d 4250fbf 4390155 4399da6 439d16d 42b7e8f 42c8965 42c85a9 42c919d 42dbbb5 104349d4 10434bc8
LC/0/0/CPU0:Apr 4 13:15:39.815 : fib_mgr[183]: %ROUTING-FIB-3-PD_FAIL : FIB platform error: fib_leaf_ldi_lw_platform_update 622: PD action CREATE failed for lw_ldi 0x5e7b5da0 flags 0x8. Shared LDI 0x6a0c403c num_slots 1 num_buckets 1 depth 1 ldi type 3 ldi protocol ipv4 flags 0x2008401 pfx 190.12.108.170/32 : 0x4ff40200 'FIB' detected the 'warning' condition 'Invalid argument' : pkg/bin/fib_mgr : (PID=188525) : -Traceback= 426e136 427855d 427be3d 4250fbf 4390155 4399da6 439d16d 42b7e8f 42c8965 42c85a9 4
2c919d 42dbbb5 104349d(TRUNCATED)
LC/0/0/CPU0:Apr 4 15:59:13.971 : fib_mgr[183]: %ROUTING-FIB-3-PLATF_UPD_FAIL : FIB platform update failed: Obj=DATA_TYPE_LDI_LW[ptr=5e8d7d88,refc=0x3,flags=0x10] Action=MODIFY Proto=ipv4. Cerr='FIB' detected the 'warning' condition 'Invalid argument' : pkg/bin/fib_mgr : (PID=188525) : -Traceback= 1035e950 1035ed4f 426e047 427855d 427be3d 4250fbf 4390155 4399da6 439d16d 421db0d 4237ef7 4238db1 4239276 421fa35 421fba5 422464e
LC/0/0/CPU0:Apr 4 15:59:13.971 : fib_mgr[183]: %ROUTING-FIB-3-PD_FAIL : FIB platform error: fib_leaf_ldi_lw_platform_update 622: PD action MODIFY failed for lw_ldi 0x5e8d7d88 flags 0x10. Shared LDI 0x6a0c403c num_slots 1 num_buckets 1 depth 1 ldi type 3 ldi protocol ipv4 flags 0x2008401 pfx 190.12.108.172/32 : 0x4ff40200 'FIB' detected the 'warning' condition 'Invalid argument' : pkg/bin/fib_mgr : (PID=188525) : -Traceback= 426e136 427855d 427be3d 4250fbf 4390155 4399da6 439d16d 421db0d 4237ef7 4238db1
LC/0/1/CPU0:Apr 4 16:33:10.263 : fib_mgr[184]: %ROUTING-FIB-3-ASSERT_CTX : BCDLdispatch [ipv4_rib pri=0 #prev_rt=0 #prev_non_rt=0] BCDLtable [0xe0000000 #upd=1 flags=0x8(local)] RTupd [IPv4:default:0xe0000000[0x59d292a4],rib,190.12.108.171/32,flags=0x400808,#paths=1[0x2052720,0.0.0.0,0x8] ver=1157829943] Leaf [IPv4:default:0xe0000000[0x59d292a4]:aib:190.12.108.171/32[ref:1 proto:ipv4 flags:0x1120001 f2:0x0 src:aib][0x659deb8c] [ref:6 pl:607b81b0 proto:ipv4 type:ip lvl:1 buckets:1 slots:1 fixup:0 flags:[o
LC/0/1/CPU0:Apr 4 16:33:10.263 : fib_mgr[184]: %ROUTING-FIB-3-ASSERT : FIB internal inconsistency detected: route new 3701 ctx flags 0x1 leaf flag 0x224000 flag2 0x0 leaf IPv4:default:0xe0000000:aib:190.12.108.171/32[src:aib] frs IPv4:aib:flags=0x1:size=28{IPv4:default:0xe0000000[0x59d292a4],aib,190.12.108.171/32,flags=0x224000,#paths=1[0x99c60,0.0.0.0]}[0x59bd18a8] : pkg/bin/fib_mgr : (PID=196716) : -Traceback= f447441 f4474cb 4396f48 439f872 421db0d 4237ef7 4238db1 4239276 421fa35 421fba5 422464e 42249
LC/0/0/CPU0:Apr 4 16:40:41.679 : fib_mgr[183]: %ROUTING-FIB-3-PLATF_UPD_FAIL : FIB platform update failed: Obj=DATA_TYPE_LDI_LW[ptr=5e7b89b0,refc=0x3,flags=0x10] Action=MODIFY Proto=ipv4. Cerr='FIB' detected the 'warning' condition 'Invalid argument' : pkg/bin/fib_mgr : (PID=188525) : -Traceback= 1035e950 1035ed4f 426e047 427855d 427be3d 4250fbf 4390155 4399da6 439d16d 421db0d 4237ef7 4238db1 4239276 421fa35 421fba5 422464e
LC/0/0/CPU0:Apr 4 16:40:41.679 : fib_mgr[183]: %ROUTING-FIB-3-PD_FAIL : FIB platform error: fib_leaf_ldi_lw_platform_update 622: PD action MODIFY failed for lw_ldi 0x5e7b89b0 flags 0x10. Shared LDI 0x6a0c403c num_slots 1 num_buckets 1 depth 1 ldi type 3 ldi protocol ipv4 flags 0x2008401 pfx 190.12.108.171/32 : 0x4ff40200 'FIB' detected the 'warning' condition 'Invalid argument' : pkg/bin/fib_mgr : (PID=188525) : -Traceback= 426e136 427855d 427be3d 4250fbf 4390155 4399da6 439d16d 421db0d 4237ef7 4238db1
Do you know what is it about?
acampbell
Looks like bug /CSCux35682
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCux35682/?rfs=iqvred
try another ios or raise a TAC
Regards, Alex. Please rate useful posts.
