ASR GLC-LH-SMD
Byron Bohlsen
We are trying to install an ASR for our Level3 connectivity which is currently in a port on our switch. When we pull the SFP and put it in the ASR it doesn't recognize the SFP so we purchased a GLC-LH-SMD and we can't ever get it to light up. The connection works on our switch so we know it's not them.
Switch inventory:
NAME: "GigabitEthernet2/0/51", DESCR: "1000BaseLX SFP"
PID:                     , VID:     , SN: FNS1005H0EG
ASR inventory:
NAME: "subslot 0/0 transceiver 2", DESCR: "GE LX"
PID: GLC-LH-SMD          , VID: A   , SN: FNS172619
Working switch port config:
 description TWT ENLAN
 switchport access vlan 357
 switchport trunk native vlan 254
 switchport trunk allowed vlan 357
 switchport mode trunk
 speed nonegotiate
ASR Config:
interface GigabitEthernet0/0/0
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 negotiation auto
interface GigabitEthernet0/0/0.357
 description MPLS to MTKA over TWT-NLAN 1Gbps
 encapsulation dot1Q 357
 ip address 10.X.X.X    X.X.X.X
 no ip redirects
 no ip unreachables
 no ip proxy-arp
Why won't the connection even light up on the ASR?
sreenivasgajula
What kind of ASR router it is?
Sounds like I'm having a similar issue on ASR903 and ASR920 with GLC-LH-SMD, when I insert the optic, it throws the following log:
%TRANSCEIVER-3-CHECKSUM_ERROR:iomd:  Detected in the transceiver module in GigabitEthernet0/1/3, module disabled
However the same optic works in a ASR901. Tried different IOS images and still no luck. Working with Cisco TAC on this.
Simple over-sight on our part. We added:
no negotiation auto
that got the interface to work great.
Hi Byron,
What do you mean "over-sight"?
