How to route beyond ROAS?
kkct
Beginner
Beginner
Okay, I'm a newbie and hope this question won't sound stupid to you guys. I've a topology shown in the figure. I use ROAS on the left hand side, and obviously I can't ping the right hand side from the left hand side. Is it possible for both sides to communicate with each other? What should I do if I want them all connected to one another? (or is this kind of topology simply wrong?)
Jon Marshall
VIP Community Legend VIP Community Legend
You just need the routers to exchange routes for their local subnets.
You can do this with either static routes or you can use a routing protocol, up to you really.
Jon
luis_cordova
VIP Advisor VIP Advisor
VIP Advisor
Hi @kkct ,
Try with this:
Router0
Router(config)# ip route 192.168.2.0 255.255.255.0 10.10.10.2
Router(config)# ip route 192.168.3.0 255.255.255.0 10.10.10.2
Router1
Router(config)# ip route 192.168.1.0 255.255.255.0 10.10.10.1
Also, you must make sure that the PCs have the correct gateway
Recognize Your Peers
