ASR Traffic shape & Bandwidth
Hello everyone,
I want to configure traffic shaping (or bandwidth) on ASR 1006 but somehow it is not working. Interesting ACL is not catch the traffic? You can see the configuration at the below.
MY PC(10.200.0.217) ------> FW (with NAT - 194.X.X.X) -------> ASR 1006 (with Traffic Shaping)
ip access-list extended POLICY_ACL
permit ip host 194.X.X.X any (THIS IP ADD is my PUBLIC IP)
permit ip host 10.200.0.217 any (THIS IP ADD is my local PC)
class-map match-any POLICY
  match access-group name POLICY_ACL
policy-map POLICY
class POLICY
    shape average 1000000
interface GigabitEthernet0/0/4
description OUTSIDE_Interface
  ip address x.x.x.x 255.255.255.252
  ip nbar protocol-discovery
  negotiation auto
  crypto map clientmap
  service-policy output POLICY
Thank you very much,
My best.
Cavit Davutoglu
Lei Tian
Hi Cavit,
That is because the order of process on router is to process queueing at then end. In your case, packets will be encrypted first, and then queue. So, the header of the encrypted packets will be either ipsec peer IP or tunnel IP, depends the ESP mode you using.
To address that, you can
1,classify and mark the traffic at LAN inbound direction. Then match the DSCP and queue on the WAN outbound direction.
2,use ipsec pre-classify on the crypto-map.
HTH,
Lei TIan
